Squealing at idle
Old Oct 13, 2019 | 09:10 PM
RedRaiderUSMC's Avatar
RedRaiderUSMC
Squealing at idle
So I have a squeal at idle that only starts when the truck reaches operating temp. It seems to be coming from the transmission area. It goes away when gas is applied, and starts again at idle. It also goes away when put into gear, but returns in park. I read on a forum someone was saying it was the transmission oil pump. Anyone have anything on this? 2019 lariat 6.7, 1000 miles, it’s done it the whole time.
Old Oct 14, 2019 | 05:20 AM
seville009's Avatar
seville009
If it were me, I’d just take it to the dealer. You’re under warranty so let Ford fix it.
Old Oct 14, 2019 | 10:45 AM
TireFryer426's Avatar
TireFryer426
I have a similar issue. 2019 F-450. Idle is the only time it doesn't do it, though. Anything off idle and you can hear it, if I touch the gas at all its there. Almost sounds like a faint brake squeal.
My transmission has been acting like its slipping as well. Hopefully getting it back in to the dealer soon.
Old Oct 17, 2019 | 12:41 PM
SUPERTRUCKERS's Avatar
SUPERTRUCKERS
I was having a noticeable squeal/whistle/chirping sound coming from the middle of the truck between 5-10 mph. I narrowed down the location after rolling downhill in neutral with engine off and the sound was not affected by applying the brakes. Had the dealer inspect yesterday and they confirmed it was the Transfer Case Output Shaft Seal as the culprit. They are replacing now. Will report back if that fixes the issue.
Old Oct 24, 2019 | 10:27 AM
SUPERTRUCKERS
...Reporting back, no issues now, squeal sound is gone after the Transfer Case Output Shaft Seal was replaced
kyle1979ford
Feb 3, 2022 05:57 PM
AUTOHAUL
Oct 10, 2019 08:29 AM
Mikeyc187
6.7L Power Stroke Diesel
23
Dec 21, 2011 06:57 PM
79FordBlake
Oct 12, 2009 03:28 PM
