FAST IDLE
Old Oct 9, 2019 | 08:46 PM
AUTOHAUL's Avatar
AUTOHAUL
FAST IDLE
Do the gas SD engines have a fast idle circuit like the diesels ?
Old Oct 9, 2019 | 09:22 PM
PentaPop's Avatar
PentaPop
Yes. Just hooked mine up last week. Not quite as easy as my old 04. The new trucks need a resistor placed in the circuit to determine the idle speed so it took a bit longer. Here’s a doc that will help you find the right wires and figure out what value of resistor you want.
https://madocumentupload.marketingas...013b9&v5=False
Old Oct 10, 2019 | 06:21 AM
AUTOHAUL's Avatar
AUTOHAUL
Looks like everything is there except the resister right ? I don't think my '05 6.0 needed the resister.
Old Oct 10, 2019 | 08:29 AM
PentaPop's Avatar
PentaPop
Yep. My 04 was a 6.0 too. Just had to apply voltage to the circuit via a switch. The addition of the resistor lets you choose what RPM you want to idle at. I’ve also seen some posts where guys are putting in a rheostat so they can adjust the idle speed. I just used a 12k resistor which set me up at about 1200 RPM. Not planning on needing to adjust the idle speed so I didn’t go the rheostat route.
Nice part is, the connector with all the wire stubs unplugs from the truck and you can solder the resistor in on the bench. Not sure I would have messed with it if I’d had to contort myself to get in there and do it under the dash. My body doesn’t fold like that anymore!
EDIT - I just saw you’ve I’ve got a 7.3 on order. I suppose Ford will release a new schematic in the event the wires are different. I’ll be interested to hear your impressions of that motor after you drive it a while!
kyle1979ford
Feb 3, 2022 05:57 PM
