radiator support
Old Oct 4, 2019 | 08:20 AM
740buckeye's Avatar
740buckeye
Trailering
radiator support
question where does the support bolt into the frame on a 1950. Is it on the most forward mount or on the innermost mount any help would be appreciated. Thanks
Old Oct 4, 2019 | 08:38 AM
schoo's Avatar
schoo
Depending on your engine 6- v8 cylinder
Old Oct 4, 2019 | 08:39 AM
schoo's Avatar
schoo
Same with inner fenders and the air dam on the hood this is the 6 cylinder on my 49
Old Oct 4, 2019 | 12:25 PM
740buckeye's Avatar
740buckeye
Trailering
it is a v8
Old Oct 4, 2019 | 12:29 PM
schoo's Avatar
schoo
Originally Posted by 740buckeye
it is a v8
Flathead ?the v8 is shorter than the 6
Old Oct 4, 2019 | 02:18 PM
TireDood's Avatar
TireDood
V8 mounts in the rear holes, 6 cylinder goes in the front holes. There are corresponding holes in the inner fenders also...
Old Oct 7, 2019 | 10:11 AM
52 Merc's Avatar
52 Merc
it is a v8
Same question. Is this a stock restoration? Are you using the flathead V8 or a later engine? Moving the rad forward to the 6 cylinder position will gain a ton of room for accessories and fan for later V8's. What is your build plan?
newguy399
Oct 25, 2017 10:44 AM
hillcountryflt
Sep 12, 2015 12:29 AM
jtckf
Apr 8, 2013 10:45 AM
dick1950
Dec 15, 2007 09:39 PM
