steering column help
Old Oct 2, 2019 | 10:20 PM
godtar01's Avatar
godtar01
Trailering
replaced upper steering column bearing and tolerance ring on 94 f350....... steering wheel now has no wobble but really stiff. I have to turn the wheel back to center when completing a turn. Any ideas?
Old Oct 3, 2019 | 10:38 AM
woodson84's Avatar
woodson84
Not sure exactly but sounds like you over-tightened something. You didn't mess with the box did you?
Is this the tolerance ring: https://picclick.com/Steering-column...541592890.html
Old Oct 3, 2019 | 08:22 PM
godtar01's Avatar
godtar01
Trailering
it is held by spring tension so ?....... one thing I didn't do is lube I am going to take apart and try with new bearing and no tolerance ring and go from there.
schlepprock250
22
Jun 3, 2011 03:51 PM
Scratcher
Nov 28, 2010 08:58 PM
big64
Jun 15, 2009 08:41 AM
Don4.6
Feb 23, 2007 07:20 PM
