Sponsored by: Real Truck
Steering box challenges
Old Oct 2, 2019 | 12:58 PM
Jimv8's Avatar
Jimv8
Just a rant; the box started leaking and I got the replacement lower seals and set to work.. getting the Pitman off was #1 task. Finding a puller wasn’t easy and the tool rental one were too small, and I ended up buying one at Princess Auto and filing a bit off the insides to get a fit. It took both feet on the breaker bar to get the arm off. I dug the outer seal out without much trouble and got to the snap ring and that ****er took hours get out, But it’s out and that’s got me to the inner seal and that bugger is stuck in real good. I got a little movement and working now to get under it without scoring the shaft or bore. I’m in for a lunch break and thinking of making a tool to do the job. Rant over
Old Oct 3, 2019 | 08:22 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Should have nust put a rebuilt box in the truck, original seems to be shot anyways
Old Oct 4, 2019 | 06:41 AM
Jimv8's Avatar
Jimv8
Well I got it done and after a day it doesn’t leak. FWIW the auto supply place has 2 listings for the seal kit, one for a shaft with 32 splines and one for 36 splines. I bought both and learned the 36 spline shaft is thicker. Makes sense.
jason832
Jul 20, 2019 07:28 AM
77'F-150Mudder
Feb 28, 2012 09:25 AM
classic79
Sep 28, 2005 10:00 PM
MG_NUT
Sep 24, 2004 08:46 AM
j.garn
Sep 12, 2003 01:56 PM
