2000 EXPY Pitman Seal
Has anyone replaced just the Pitman shaft seal in the steering box?? Both Dealer & Repair shop want to swap out the steering Box (Not Good $$$ plus posts on here about steering sensativity hate to get bad box), Seal Kit is like $15 Looks not fun, but beats $350.Also, area looks all oily, but fluid level holding its own, may just live with it!
Any hints??
If it isn't gushing out, just a little weep, I'd leave it. You might just make it worse by fiddling with it. Getting the pitman arm off the box is a bugger unless you've got a torch.
