Sync 3.0 update
Old Dec 10, 2019 | 10:22 PM
  #76
ForCal's Avatar
ForCal
Originally Posted by JHForman812
have you checked your version? my 2019 came with 3.0, 3.0 is pretty stable, 3.3 is very stable, 3.4 seems to be stable and has the new maps 1.18
It says Build 18093 and Navigation version 1 17. I don't know what the difference would be with the update they informed me about via email.
I like that new version that you have, for now I think I want to wait, see if any issues are discovered and fixes found. Basically just make sure its stable and any bugs worked out.
Old Dec 10, 2019 | 10:47 PM
  #77
JHForman812's Avatar
JHForman812
ive yet to see any issues with either 3.3 or 3.4 ive played with both. 3.4 GUI looks better though. I went back to 3.3 because I like the all black night mode.
Old Dec 11, 2019 | 07:11 AM
  #78
BocaIvan's Avatar
BocaIvan
Is it possible to just do the 1.18 maps?
Old Dec 11, 2019 | 07:34 AM
  #79
Andrewalker7's Avatar
Andrewalker7
Seconded... I want to keep all of my Forscan settings, I just want the missing roads to be filled in
Old Dec 11, 2019 | 07:35 AM
  #80
Andrewalker7
the Lincoln theme in the new 3.4 is pretty sharp IMO
Did you have the Lincoln theme on the truck through Forscan, THEN updated? Did everything stay put? What does it look like?
Old Dec 11, 2019 | 07:14 PM
  #81
JHForman812
you don’t lose your forscan settings(like heated seats/wheel on screen all those stayed)
Old Dec 11, 2019 | 07:18 PM
  #82
JHForman812
I wasn’t running the Lincoln theme prior to the 3.4 update I didn’t like it! I like the Lincoln theme in 3.4
Old Dec 12, 2019 | 11:24 AM
  #83
Andrewalker7
Anything else missing with it? I have the manual regen enabled, light settings, etc.
  #84
Andrewalker7
Not bad. I went with the Lincoln theme, as it better suited the King Ranch interior colors. Unsure on that one ^
Old Dec 26, 2019 | 07:49 PM
  #85
slapshot12's Avatar
slapshot12
I took my truck in last week to get the broken sunroof frame replaced. I asked them about the TSB for the stereo always reverting to AM. They did the TSB and it now always stays on XM....finally!!
Old Dec 30, 2019 | 07:05 AM
  #86
40Grit's Avatar
40Grit
Can anyone report that the 19025 Build has been trouble-free? Has this fixed the bright display screen when remote starting?
Old Dec 30, 2019 | 09:53 AM
  #87
ForCal's Avatar
ForCal
I did the update a couple weeks ago, I haven't noticed any issues. IIve never heard of the remote start bright display thing, What is it?
Old Dec 31, 2019 | 05:36 AM
  #88
40Grit's Avatar
40Grit
The dimming issue is common to the super dutys and F150s. When you remote start and the SYNC display is set to automatic dimming, the screen comes on at full brightness when you get inside and start the truck. To get it to the correct dimming setting, you have to manually bump the dimming buttons then the screen goes back to the brightness it was originally set at. This did not happen with the older SYNC software versions. This is especially noticeable at night.
Old Dec 31, 2019 | 10:39 AM
  #89
ForCal's Avatar
ForCal
Hmm, I cant say I've noticed, I've only remote started in the daytime so that might be why. I do hate how bright the screen is at night time when the start button is pressed and headlights are off. I have to change it from auto to night to avoid that. It should just know it's dark out and automatically dim regardless of whether or not the lights are on.
Firefighter 1406
Oct 21, 2011 09:51 AM
