TWOdifferent types of factory installed integral A/C systems. Note how the hoses connect to the compressor:
I'll list the sources for NOS once I know what type of A/C system the OP's truck has.
E3TZ-19972-C .. Discharge Line - Compressor to Condenser - Use with hoses connected directlyto the compressor (Motorcraft YF-1099) / Obsolete
1983/86 F250/350 460
E3TZ-19972-H .. Discharge Line - Compressor to Condenser - Use with hoses connected to service valves on the compressor (Motorcraft YF-1106) / Obsolete
1983/86 F250/350 460. ------------------------- E4TZ-19837-B .. Liquid Line - Dryer to Evaporator - Use with hoses connected directly to the compressor (Motorcraft YF-1214) / Obsolete
1980/86 F100/350 & Bronco all I-6 & V8.
E4TZ-19837-A .. Liquid Line - Dryer to Evaporator - Use with hoses connected to service valves on the compressor (Motorcraft YF-1213) / Obsolete
1980/82 F100/350 & Bronco all I-6 & V8 except trucks assembled in Twin Cities MN & Norfolk VA // 1983/86 F100/350 & Bronco all I-6 & V8. ---------------------------------------------------------------------------------------------------------------------------------------------------- E4TZ-19867-E .. Suction Line - Evaporator to Compressor - Use with hoses connected directly to the compressor (Motorcraft YF-1222) / Obsolete
E4TZ-19867-G .. Suction Line - Evaporator to Compressor - Use with hoses connected to service valves on the compressor (Motorcraft YF-1224) / Obsolete
After seeing my compressor and how I have the manifold blocks, is that directly to the compressor or service valves?
I would not use r134a on a NOS hose. Most new hoses are r134a compatible hose, I would ask who you buy them from before spending any money. Old R12 hoses exposed for years to the r12 and the r12 oil will seal against the r134a. But a brand new never used NOS r12 hose is not going to be leak free to r134a.
Well shoot. Ok. Didn’t know there was that big of a difference in them. I’ve heard so many stories of just switching refrigerant and small things. I do have someone local that can make them, it’s just a matter of getting the day off and having to take the truck there.
