Cannot turn off overdrive 2000 Expedition
Old Sep 30, 2019 | 10:50 PM
JoeDirte's Avatar
JoeDirte
I recently found a good reason to turn off overdrive in my expedition. I am now towing a 4000+ pound camper. I have a hilly drive to the lake and towing is tough for the old girl. I press the OD off button on the shift lever. The od off light does come on. However, i feel nothing. The transmission is still shifting into overdrive. No engine braking either.
Does this seem like a button/wiring issue? Or more like a transmission problem? Anyone with similar issues maybe?
Old Oct 1, 2019 | 06:14 AM
projectSHO89's Avatar
projectSHO89
Yes. Pull column shrouds and inspect the little wiring harness that goes into the shift lever tube. Test the switch operation using a meter. Etc...
The button is an input into the PCM that tells it what you want so it can make the changes to the transmission. Sounds like your PCM isn't getting the input.
Old Oct 1, 2019 | 10:14 PM
JoeDirte's Avatar
JoeDirte
If the light comes on when the button is pushed does that mean that the button if functioning properly? Does the button turn the lamp on or does the pcm give this signal? Maybe someone could point me in the right direction for a wiring diagram.
Old Oct 2, 2019 | 05:32 AM
projectSHO89
The button is the input to the PCM. The PCM controls the bulb.
Schematic is attached.
Old Oct 2, 2019 | 09:33 AM
alloro's Avatar
alloro
I'm not sure you've thought that one through. The PCM would have to get a signal from the OD switch in order to turn the bulb on, correct? I too would think that since the bulb is turning on then that means the PCM is receiving a signal from the switch and the issue should be from the PCM to the tranny.
Old Oct 2, 2019 | 12:58 PM
projectSHO89
Yeah, that's what happens when I skim over the post and don't read it completely... Missed the part about the light coming on. Good catch!
Old Oct 2, 2019 | 08:30 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The button completes a circuit to the PCM. When that circuit is complete the PCM cancels OD. When OD is cancelled all that happens is that the PCM does not tell the transmission to shift to overdrive.
You should check for codes.
Old Oct 2, 2019 | 08:47 PM
JoeDirte's Avatar
JoeDirte
Thanks for the help everyone! O have an Obd2 code reader (a cheap one) and I have scanned for codes with Forescan and did not see any codes. Would my check engine light come on with these codes or would i need a better scanner?
Old Oct 2, 2019 | 09:39 PM
Mark Kovalsky
Forscan can read the transmission codes. A cheap code reader will not read transmission codes. The check engine light will come on with some transmission codes, but not all transmission codes.
Old Oct 2, 2019 | 10:09 PM
JoeDirte's Avatar
JoeDirte
Thanks again. I am going to do some more diagnostics with Forescan maybe I'm overlooking something. I have a mechanic buddy that thinks I am actually turning overdrive off and I am crazy. Maybe I am! We're going to do some driving and see what we think.
Old Oct 2, 2019 | 10:13 PM
Mark Kovalsky
With Forscan you can look at live data. Look at a parameter called GR_CM. That is the commanded gear. If it never goes to 4 overdrive is off.
twells32
Aug 19, 2007 09:58 AM
easttxguy37
2004 - 2008 F150
May 20, 2007 09:47 PM
bigbobe
Sep 21, 2004 01:51 PM
Doughboy55
Aug 16, 2004 04:21 PM
jfroda
Jun 12, 2001 02:19 PM
