overdrive out ?
Old May 16, 2007 | 07:14 PM
easttxguy37's Avatar
easttxguy37
overdrive out ?
i have a 2004 ford f150. the over drive has gone out,can i drive it still or what do i need to do?
Old May 16, 2007 | 07:17 PM
NASSTY's Avatar
NASSTY
How can you tell your OD is out? What are your rpms at 55mph?
Old May 20, 2007 | 08:41 PM
easttxguy37
when the overdrive button is turned on, the truck will not shift into the last gear...its like it goes into neutral...if i turn off the overdrive button, it runs fine, it just runs on higher rpm's...
Old May 20, 2007 | 09:47 PM
jcsv99's Avatar
jcsv99
Cool
Had the same issue with a previous car. THe OD whent first, and then others started to go. I would take it to someone you trust - some fly by night shop will tell you anything to get a tanny replaced.
joe f350
Jul 1, 2010 08:42 PM
nflfreak43
20
Jun 19, 2010 05:25 PM
DCFord
30
Mar 2, 2010 05:14 AM
