Ball joint replacement/alignment
Old Sep 29, 2019 | 02:50 AM
StrokinHer01's Avatar
StrokinHer01
I’m going to have to change my ball joints soon and have been hearing about the castor/camber sleeve needing to be aligned... it looks like on my truck that sleeve is fixed in one position and unable to be rotated/moved... any input is appreciated. Also been looking but unable to find greasable moog joints uppers and lowers..
2001 f250
Old Sep 29, 2019 | 06:53 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
2001 f250
Yes you need it aligned. Check you steering components as well. That way you get everything replaced that needs it, before the alignment.
Old Sep 29, 2019 | 08:19 AM
Walleye Hunter's Avatar
Walleye Hunter
IIRC it can be knocked out of position when the ball joints are out (or maybe even just loose). I used NAPA ball joints and they had zerks on them but I had to grind one of them down so the U-joint wouldn't break it off. Which reminds me that I need to check and verify that it didn't get knocked off.
Old Sep 29, 2019 | 09:00 AM
2001F350dualwheel's Avatar
2001F350dualwheel
I would mark the sleeve to get you back to close to where you started before loosening/removal of the upper ball joint nut.
I've rebuilt one D50 and two D60s. Marking the sleeves got me back to where I didn’t need to realign two of the three trucks.. granted this is assuming you didn’t need a alignment. There is a mark once the sleeve is removed that tells you the range of adjustment it’s able to complete, there are a lot of different adjustment combos. What I would do is find a specialty shop that deals with these big trucks.
as for the ball joints I’ve used Dana Spicer factory stuff on one truck. No greasable zerks. It had 160,000 miles on the original ones when I replaced them. I doubt I’ll be doing them anytime soon.
On the other truck I used Napa Gold greasable. On the uppers I used the little block off cap. I only went with Those because I couldn’t get the Dana Spicer ones in time. I was selling the truck and I had a guy who supposedly was hot to buy it. Of course he flakes out never to be heard from. But that’s ok they are fine. Whoever is gonna buy tha5 truck has a fully rebuilt axle outer sections.
The last truck was a buddy who was getting stationed in Virginia and had to drive cross country and his front end was a mess. I rebuilt it for him. I wasn’t gonna let him drive 3000 miles like that with his family. Same Napa gold parts.
Old Sep 29, 2019 | 09:47 AM
pirate4x4_camo's Avatar
pirate4x4_camo
1. only use spicer ball joints, they are what your truck was made with and are better quality then moog snd others
Ventures had great service and spicer genuine ( ebay and internet are full of counterfeits )
https://venturestruckparts.com/produ...le-parts-kits/
2. mark your inner bushing to the outer snd reassemble the same to get your current alignment when reassembled. clean all matting surfaces to spotless snd torque to factory specs
3. my preferred alignment spec
+.03* toe
+4.5* caster with *.05* split
0* camber
0.0* steer ahead
Old Sep 29, 2019 | 04:16 PM
StrokinHer01
The alignment is where it should be so I don’t think it needs it. After I put the new joints in myself can it still be aligned by a shop?
Old Sep 29, 2019 | 04:28 PM
2001F350dualwheel
I dont see why not.
Old Sep 29, 2019 | 05:51 PM
StrokinHer01
Originally Posted by 2001F350dualwheel
I dont see why not.
I was was just curious the procedure of alignment
Old Sep 29, 2019 | 08:54 PM
2001F350dualwheel
Just index mark the alignment bushing to the knuckle so it goes back in the same spot and that should put you close enough to the starting point.
Old Oct 1, 2019 | 01:25 PM
SteveH-CO's Avatar
SteveH-CO
$78/side for the genuine parts seems very inexpensive. Thanks for the link!
Old Oct 1, 2019 | 08:34 PM
2001F350dualwheel
That was where I bought my kits. They have a Ebay account. The Timken hubs were actually cheaper at RockAuto. Sadly I’m actually selling that truck because I don’t use it much anymore.
bma2001
Feb 19, 2015 05:14 PM
robinsonpowerstroke
16
Jan 3, 2011 10:27 AM
sg2004
Nov 8, 2010 10:15 PM
Ryan50hrl
2004 - 2008 F150
May 17, 2009 10:14 AM
nelly781
1978 - 1996 Big Bronco
Oct 21, 2006 05:03 PM
