Sponsored by: Real Truck
camber sleeve replacement
Old Nov 8, 2010 | 09:27 PM
sg2004's Avatar
sg2004
I'm in the middle of replacing my ball joints on one side and the installation instructions that came with the Moog ball joint says the Camber sleeve must be replaced if I had a loose, bent, or broken upper ball joint stud. Well I saw play in the upper ball joint - that's why I'm replacing it but the sleeve looks pretty rusted in there. Should I go ahead and bust my butt trying to get that sleeve out or could I leave it in?
Old Nov 8, 2010 | 10:15 PM
jaceharp's Avatar
jaceharp
if there is no damage leave it in, it is not nec. to replace it every unless the camber and/or caster needs to be adjusted
LSO1123
Apr 23, 2014 05:36 PM
mechelement
Nov 7, 2011 06:57 AM
Jessefro
Jul 30, 2010 05:42 PM
78longbed
Nov 10, 2008 06:52 AM
1972f1004x4
General Automotive Discussion
Oct 19, 2004 08:10 PM
