1978 - 1996 Big Bronco
ball joints
Old Oct 18, 2006 | 06:22 PM
nelly781's Avatar
nelly781
ball joints
isnt there a website that has the ball joint replacement pictures and step by step instructions??? my tires look like this /---\ and its killin my tread. so i need to fix this soon and adjust my camber while im at it. anyone got any help?
thans ahead of time
Old Oct 18, 2006 | 07:20 PM
andym's Avatar
andym
If your camber is off, it's not necessarily ball joints. Have you actually diagnosed the problem as bad ball joints?
Old Oct 19, 2006 | 11:45 PM
nelly781's Avatar
nelly781
no i have not, i replaced them about 2 years ago, so im not really sure, i figured while im in there i might as well replace them if my knuckles are taken apart
i agree that my camber is off deffinately. but i remember there being a website about someone changing their ball joints and i assumed it had somethin on there bout adjusting the camber
thanks
Old Oct 20, 2006 | 02:46 AM
b4hntn's Avatar
b4hntn
A shop installed adjustable cams in mine to correct it.
Old Oct 20, 2006 | 09:16 AM
MinnManBroncoFan's Avatar
MinnManBroncoFan
Lots of these trucks were way off form the factory cam's will fix this.
Jack up the truck and grab the tire one hand on top and one on the bottom and try to move the tire.
If ball joints are shot you will have alot of movment.
Ball joint's will last a lot longer then 2 year's unless you drive 50k a year.
Old Oct 20, 2006 | 11:50 AM
nelly781's Avatar
nelly781
by cam's you mean camber? i think i kn ow what your tlakin about, that hollow pipe with the teeth around the top outside of the pipe. and also at the top of the little pipe, where the teeth are, it gets progressively bigger as you turn it, like a spark plug gapper. its on the upper ball joint.
i was lookin at that. ill probably mess with it and just stick a level to my disc brake to make sure its straigh up and down.
Old Oct 20, 2006 | 12:19 PM
93Mule's Avatar
93Mule
There is a link in this thread about ball joint replacement..
https://www.ford-trucks.com/forums/5...ht=ball+joints
Old Oct 20, 2006 | 01:46 PM
andym's Avatar
andym
You might want to get an alignment done.
Old Oct 20, 2006 | 01:49 PM
b4hntn's Avatar
b4hntn
The front end shop said after installing the adjustable cams they have to just play with it until the caster and camber are correct.
Old Oct 21, 2006 | 01:07 PM
dwoodler's Avatar
dwoodler
The front end shops do that even with the stock setup - play with the adjustments til everything lines up.
Nelly - Make sure the weight of your truck is compressing the front end when you check the disc's or your tires will look like /---\ when you are done.
Old Oct 21, 2006 | 05:03 PM
b4hntn's Avatar
b4hntn
They also installed cams on mine before they could play with it.
firebug
Aug 14, 2011 01:45 PM
magnet1
2004 - 2008 F150
Jun 30, 2011 09:24 PM
jplinville
Jan 30, 2010 09:25 PM
chris r c
New Member Introductions
Sep 5, 2008 07:10 AM
Torky
Nov 5, 2002 09:37 AM
