Alignment needed after ball joint replacement?
Old Jan 1, 2011 | 10:20 PM
robinsonpowerstroke's Avatar
robinsonpowerstroke
Tomorrow afternoon I am going to be replacing the upper and lower ball joints on a truck at work. It is a 1999 F350 5.4 gasser. I wouldn't think that an alignment would be needed after I get done but maybe. What is your guy's opinion? Thanks for the input.
Old Jan 1, 2011 | 10:29 PM
American Air-1's Avatar
American Air-1
I agree Justin. As long as it wasn't aligned before with bad ball joints, then you would need to set it back after you were done. Theres not much adjustment on those anyway.
Old Jan 1, 2011 | 10:30 PM
robinsonpowerstroke
Exactally what I was thinking. The truck only has 54k on it so im sure they are stock joints.
Old Jan 2, 2011 | 08:27 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
yes get the alignment....
Old Jan 2, 2011 | 08:38 AM
Confederate Diesel's Avatar
Confederate Diesel
When I replaced all 4 of my 2WD ball joints, I also would have thought it not necessary to do an alignment. Boy was I wrong! Yes, get the alignment. You may save yourself the cost of premature new tires.
Old Jan 2, 2011 | 08:41 AM
robinsonpowerstroke
Ok will do for sure then.
Old Jan 2, 2011 | 10:33 AM
Snowseeker's Avatar
Snowseeker
yes alignment is needed. No two ball joints are the same so say your ball joints are good to start with and you replace them with the same brand ball joints your alignment will be off.
Old Jan 2, 2011 | 11:11 AM
Waltdog's Avatar
Waltdog
of American machinists
Depends on the type of alignment being done. If it is the cheap alignment ($50-$75) then the only thing they are adjusting is the toe in and steering wheel center. When you get into the more labor intensive alignment ($200+) then you are getting new buckets under your top ball joints. Normally once they throw it on the rack they can tell you what needs to be done next.
Old Jan 2, 2011 | 11:15 AM
Jessef250's Avatar
Jessef250
Yes do it!! No doubt about it
Old Jan 2, 2011 | 02:06 PM
robinsonpowerstroke
I was thinking the same thing. I had ball joint shims put into my truck which ended up running about $200. I think I am just going to keep an eye on the tires and watch for odd wear since I did a tire rotation also.
Old Jan 2, 2011 | 05:22 PM
lhud's Avatar
lhud
Justin,
I'm in the process of doing both top/bottom - have done the driver's side so far.
My understanding is that if you do not tamper with the existing shim on the top ball joint and you had no alignment problems prior, then you should be good to go. I still would keep an eye on the tires and do as a "norm".
If a new alignment requires shimming on the top ball joint, they will have to unbolt the top of the upper ball joint and replace that shim and re-torque - I think that's right.
Old Jan 2, 2011 | 05:32 PM
USAF CCM's Avatar
USAF CCM
Totally agree.....you might need shims on the top ball joints to align within specs.
robinsonpowerstroke
Originally Posted by lhud
Justin,
You are correct. I've done this to my truck.
Old Jan 2, 2011 | 08:20 PM
danskool's Avatar
danskool
Go Bills !
I had 50% worn tires when i did my ball joints. I don't have any problem with not getting realigned on used tires. I even replaced the left tie rod end. I only get checked/aligned when i get new tires or if i have an issue. When i did get new tires i had the alignment checked, And it was good to go.
Old Jan 2, 2011 | 08:26 PM
robinsonpowerstroke
My boss just bought the truck. I would say that the tires are at probably 75%. I will just keep an eye on them and if need be, get an alignment.
