94 7.3l IDI E4OD issues
Old Oct 20, 2019 | 03:31 PM
  #46
Mattmfharris's Avatar
Mattmfharris
Originally Posted by lonewolf_
BTW there are some aftermarket controllers IF you have Deep Pockets .......so that is something you might look into ..... I wasn't interested.
it's easy enough to convert it to a manual shift BUT you will need a PWM valve controller for the EPC...
I have designed a Test controller using DRV101 IC ... I have used this to replace the VRV on the C6 Tranny and it works fine .. it also controls the EPC just fine.
you can use the original MLPS switch signals with minor logic and a solenoid Driver board to select the solenoids to engage depending on where the shift lever is positioned... the TCC is manually controlled and you won't have any automatic Kick down control... it would be easy to Trash the Tranny using this method so I won't Post my schematics. but I have just given all the info needed to build one the solenoid select pattern is already given in this Thread too.
yes I saw some of those aftermarket controllers floating around online and i will probably go that route if I can’t find an oem one easily. The part number on my pcm is f4tf-12b565-ea. From reading your post I think I can replace this with part number f4tz-12b565-ea. Is that correct? That part number seems like it will be much easier and less expensive to find in my area.
Old Oct 20, 2019 | 09:29 PM
  #47
Mattmfharris
Got a new pcm ordered
Well I ended up heading to my wife’s work (she works at an auto parts store) and got the same part number pcm ordered. Should be here in 7-10 days so after it arrives I will install it and then post what happens!!! Oh and after the employee discount I paid...... 80$ bucks shipped for a reman unit! Haha not bad in my opinion!
Old Oct 21, 2019 | 12:54 AM
  #48
icrman's Avatar
icrman
For future reference what auto parts or supplier did you get it at. Years ago there were none that oriellys could find I had to wait a month or more for mine to be fixed. It had some water leak into it and destroyed a resistor, I can't stand the black box pcm's, that you can't get any info on, to repair them. All you can do is eye ball the components like electrolytic caps etc, and change them.
Old Oct 21, 2019 | 12:16 PM
  #49
lonewolf_'s Avatar
lonewolf_
Scope Wizard
yes that is correct .. I guess you have the Turbo Diesel... my 93 is NA non turbo... the only real difference I think is in the Firmware of the PCM
Old Oct 21, 2019 | 12:27 PM
  #50
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Originally Posted by Mark Kovalsky
I don't understand this. The EPC is a variable force solenoid, not a PWM. It controls pressure based on the current supplied to it. Are you saying you can use a PWM controller to do this?
I built a controller without any logic boards to do this. It was for a specific racing series that didn't allow any type of computers, and even a simple logic board was considered a computer.
It worked, for a while. The forward clutch drum cannot handle max pressure and this system had no provision to reduce pressure when in 1, so the forward clutch drum blew apart.
Nice ... my use of logic was to just steer the signals from the MLPS to drive the proper solenoids via a Drive board so I'm not putting Drive current thru the switch itself. ... I guess I may as well add since the MLPS is a voltage divider you have to either make mods to the switch internally to get individual selections out of it OR use Logic decoding. OR just use external switches and not bother with the MLPS. I just wanted to keep the function of the MLPS and not have to flip switches.
and yes you can pretty much drive any solenoid using PWM ==>> here is a link to the Data sheet of the IC I use ==>> HTTP 301 This page has been moved
Like I say it's still not Bullet proof
Just in case that link doesn't work here is the PDF
Old Oct 22, 2019 | 06:51 PM
  #51
Mattmfharris
howdy it is a cardone reman unit. bought it from a local parts store known as cost less auto parts in my town. same units can be bought form 1aAuto.com. Cardone is not neccessarily my first choice when it comes to quality parts but hey for the price with a 1 year warranty It'll get me through for at least a year and in the mean time ill round up a known working ford unit
Old Nov 11, 2019 | 08:50 AM
  #52
Mattmfharris
Tranny is working beautifully!
Hey guys finally got my hands on the new tcm! Plugged it in and I swear this tranny works like it is brand new! Can’t wait to start driving this truck once I get some other odds and ends it needs taken care of. Thank you to mark and lonewolf! You guys helped me keep this ole girl on the road!
so when I pulled the old pcm out it was extremely rusty in fact I had to use a hammer and punch from inside the cab to knock it out of it mounting location. Is there a commonly known water leak issue that could have caused this?
Coz2122
Jun 8, 2015 09:04 PM
Brant Bowrifle
Aug 12, 2012 12:20 AM
screaminford
Jan 24, 2011 09:29 AM
1bigjoe
Jan 26, 2010 09:08 PM
hammlm
Jul 9, 2007 07:18 AM
