Sponsored by: Auxito
Water leak
Old Sep 21, 2019 | 10:40 PM
Sammy Reed's Avatar
Sammy Reed
Water leak
I have a 1997 Ford F150 with a 4.6lt got a water leak between motor and trans can see water behind alternator under intake exhaust. If it's the heater hose can I replace it without taking exhaust off
Old Sep 22, 2019 | 08:52 AM
steve(ill)'s Avatar
steve(ill)
that is the intake MANIFOLD... You need to get a better closeup view of what is leaking.. The thermostat housing and hose connections are changed without removal of the manifold. If your leaking at the crossover tube or tube in the valley of the motor, then the manifold has to be removed.
Shovelheadrob
All Things Towing
19
Jan 7, 2017 07:20 PM
rvpuller
All Things Towing
Nov 14, 2016 09:19 AM
therockgod
Sep 22, 2010 02:33 PM
Sirdrinksalot
Aug 6, 2008 12:19 AM
LarryMac
1997 - 2003 F150
Mar 4, 2005 06:33 PM
