Catalyst System Efficiency Below Threshold
Old Sep 18, 2019 | 09:38 PM
wrvond's Avatar
wrvond
I keep getting an alert on my phone (Sprint Drive) that the Catalyst System Efficiency is below threshold, then I get an alert that the Catalyst System Efficiency below threshold Bank 1 has been fixed.
Any ideas what might be going on? This keeps happening over and over and I’m worried it’s a precursor to something failing.
Old Sep 18, 2019 | 10:09 PM
slorider's Avatar
slorider
Any codes?
Old Sep 18, 2019 | 10:24 PM
m-chan68's Avatar
m-chan68
What vehicle are we referring to? A catalyst system efficiency below threshold trouble code is a gas engine trouble code. This is the 6.7L diesel forum.
Old Sep 18, 2019 | 10:44 PM
kper05's Avatar
kper05
It would have to be P0420 - Catalyst System Efficiency Below Threshold (Bank 1).
Old Sep 19, 2019 | 05:23 AM
senix's Avatar
senix
wonder if a EGT sensor is having an issue? Could that be the cause of the code?
Old Sep 19, 2019 | 05:45 AM
wrvond's Avatar
wrvond
I’m on the road.
There’s nothing indicating any kind of problem except the Sprint Drive. It’s a module plugged into the OBD2 port to provide WiFi. It also reports vehicle health and status much like Ford Pass.
EGT sensor does sound like the most likely candidate.
Old Sep 19, 2019 | 07:02 AM
kper05's Avatar
kper05
Do you have another type of OBDII device with scan tool app you can try to see if it alerts? It is possible the device is reporting this in error or is causing network issues.
Old Sep 19, 2019 | 06:20 PM
wrvond's Avatar
wrvond
I do have an OBD2 scanner I plan to use when I get home. Until then I’m not too worried as everything seems to be working fine and without the cell phone alerts would have any clue there might be a problem.
RobbD
Nov 22, 2013 06:55 PM
Fat Ford Boy
2009 - 2014 F150
34
Mar 22, 2011 12:41 AM
Togaduke
Aftermarket Products
Feb 23, 2004 10:07 PM
