Continuous lean bank 1 code help please
Old Sep 18, 2019 | 06:04 PM
preston74's Avatar
preston74
We have a 2006 e250 4.6 liter work van. Need help determining cause of long term fuel trim + 20 percent bank 1. No signs of vacuum leaks or injector faults on scan tool plus no misfire codes but at idle very poorly running and shaking. O2 sensor data and switching look good after removing spark plugs bank 1 noticed some oil around plug end and after replacing all four plugs fuel trim was normal about 3 percent +\- for week or so then today again van starting rumming real tough at idle and after scan tool long term fuel trim back above 20 percent bank 1. Question is what would cause van to run good for couple weeks with new plugs then again have lean fuel trim bank 1 return to pre plug replacement so quickly.
Danner717
1983 - 2012 Ranger & B-Series
26
Sep 17, 2015 01:21 AM
Kevin Parsons
1997 - 2003 F150
21
Oct 16, 2014 01:40 PM
procrstinator
Jun 11, 2007 07:26 AM
FordMan190
Apr 26, 2005 08:21 PM
SgtJoe
Aerostar
Dec 22, 2004 01:01 PM
