E40d issues
Old Sep 17, 2019 | 10:42 PM
Ayden Goode's Avatar
Ayden Goode
E40d issues
I have a 1991 F250 7.3l idi n/a with the E40d. For 2 months it’s sat being moved only every week or so while being painted and a few days ago i went to start it and the battery had died. So when i recharged and and started it i put it and drive and it would only go into 4th(or 2nd if i manually selected it). The tach has previously worked irraticly but now doesn’t work at all and the od light glows continuously. The trans was rebuilt just under a year ago. After lots of trouble shooting i know the eec relay works, but i think the pcm might be bad? Or there’s no power to the trans. I’m stuck in a hole as I’m not sure how to troubleshoot further so please help!!!
Old Sep 18, 2019 | 10:33 AM
Scott in TX's Avatar
Scott in TX
Who rebuilt the transmission?
Who installed the rebuilt transmission?
Have you hooked up a reader to see if there are any codes the transmission is giving?
Was only the outside being repainted? did they remove panels/hood?
I would make sure your tach sending unit/wires up near the oil cap is ok,
Old Sep 18, 2019 | 11:04 AM
Ayden Goode
Update -kind of found the issue. I was fiddling around with connectors coming to and from the pcm, something worked and all functions returned to normal. However when i go over bumps it will disconnect again and go back and forth in and out of limp mode. Just have to find the loose connection now. Any common ones?
DieselRugger
Dec 15, 2022 01:33 AM
madvillepocket
May 16, 2015 09:04 PM
plowboycowboy
Oct 4, 2014 12:31 AM
bnuts677
17
Jan 19, 2013 12:27 AM
1988FordBeast
23
Jan 18, 2012 10:30 PM
