Has it been driven enough to clear any readiness codes? Thad would hang you up for a while.
I think you should read this thread or at least post #8 where the poster goes through the drive cycle readiness
steps so that you can have it set si you can take the test. >>> https://www.ford-trucks.com/forums/705891-new-egr-info.html]drive cycle readiness[/url]
[I have driven it over 700 miles with at least 7 heat cycles.
[=Yahiko;18852233]Has it been driven enough to clear any readiness codes? Thad would hang you up for a while.
steps so that you can have it set si you can take the test. >>> https://www.ford-trucks.com/forums/705891-new-egr-info.html]drive cycle readiness[/QUOTE]
Scaned for codes and found no egr codes , just ficm no compatible with program and keep alive memory. Scan with snap on Modis and fixed module. Ficm was changed 4 years ago and truck runs great.
