Name these things?
Old Sep 15, 2019 | 06:18 AM
Kramercd's Avatar
Kramercd
Name these things?
I have some ideas, others I don't have. Some I did know and have since forgotten.
loose crimp cap on right side of c6
plug just behind timing cover
in the center on the right of fuel pump slot, shiny circle looks like aluminum plug, has a dimple like someone started to drill it out
Giant threaded rod sticking out of what looks to be a block provision for dipstick
what are those rings and are they supposed to stick out?
they are just a bit recessed on these
Old Sep 15, 2019 | 07:00 AM
Franklin2's Avatar
Franklin2
The picture below is a breather. As the oil gets hot in the trans it expands, this lets the air in and out as the oil expands and contracts, and makes an effort to keep dirt and water splash out.
Old Sep 15, 2019 | 07:02 AM
Franklin2's Avatar
Franklin2
In the picture below, those are your lifters. They ride on the camshaft and push up on the pushrod which is the long rod above each one. That pushrod in turn pushes on your rocker arms under the valve cover, and that opens the valves. Some are up, some are down because of the firing order of the engine.
Old Sep 15, 2019 | 07:03 AM
FuzzFace2's Avatar
FuzzFace2
Need to take the pictures back a little farther so we can tell where & what we are looking at in some of them.
The last 2 pictures are the lifters that ride on the cam shaft.
As the cam turns it pushes up the lifter, why it is out of the lifter bore, that then pushes the push rod that moves the rocker & valve.
First picture I am going to say is a vent for the trany. You see that type of "loose cap" on the end of hoses that go to the rear & front (if 4x4) axle housings and to transfer cases.
This hose is then routed up into the frame (rear axle), firewall (transfer case), or radiator support (front axle) so if going thru deep water / mud water will not get into them and the cap is to keep out bugs.
Other pictures it is hard to tell what they are.
Dave ----
Old Sep 15, 2019 | 07:04 AM
Franklin2's Avatar
Franklin2
Here's what the lifters look like.
Old Sep 15, 2019 | 07:15 AM
Kramercd's Avatar
Kramercd
Dave ----
I might be able to get them to turn out now that the sun is up. This phone takes really low quality photos though and I can't get enough light in the shop.
All the engine pictures are taken of the left side. Will see if I can get better pictures.
Old Sep 15, 2019 | 07:59 PM
Kramercd's Avatar
Kramercd
see if these are any better
Old Sep 16, 2019 | 01:28 AM
Kramercd's Avatar
Kramercd
@NumberDummy It didn't occur to me until now to think to ask you about 300 6 blocks. There are 3 different styles, if I remember correctly. Could you shed some light on this?
Old Sep 16, 2019 | 01:32 AM
Kramercd's Avatar
Kramercd
I was looking around at garys place, and found this image.
This looks like the aluminum plug in my photo that someone tried to drill, any idea what this is? Or was?
Old Sep 16, 2019 | 02:32 AM
matthewq4b's Avatar
matthewq4b
Where that bolt is sticking out the blook beside the Oil filter is where the dip stick goes there is another spot for a dip stick beside the fuel pump first pic.. There are 2 locations for dip sticks on the later 300 blocks. You have to remember the 300 used in a lot of applications, Automotive, Off-highway (construction equipment, Aircraft tugs, Forklifts man lifts etc), Agricultural, Stationary, Marine, Industrial and Power Generation. And there are literally a dozen or more Oil pans for the 300. Ford used to cast a few different 300 blocks depending on the application. Towards the end of production, Ford was pretty much just casting one block for Automotive and the Power Product applications (non-automotive) and machining just as needed. So some of these blocks may have things like multiple locations for dip sticks. I do know for sure though the later replacement and maybe some of the later blocks were all machined the same regardless of application.
Old Sep 16, 2019 | 02:39 AM
Kramercd's Avatar
Kramercd
Originally Posted by matthewq4b
Where that bolt is sticking out the blook is where the dip stick goes.
That's what I was thinking, wanted a second opinion. The block was cast at the end of '95. Not sure how they got it in there unless it was a big bolt and they cut it down after. Doesn't appear to be near enough room between it and the block to get some jam nuts on there.
Sparky83
North Carolina Chapter
24
Sep 18, 2019 02:43 AM
AKBray907
1997 - 2003 F150
Jan 10, 2014 01:20 PM
nflfreak43
Jun 15, 2011 01:36 PM
Adam0331
Mar 12, 2009 08:57 PM
PinkStroker
91
Nov 13, 2008 10:51 AM
