Advice Needed on Replacement A/C Compressor
Old Sep 14, 2019 | 11:25 AM
Texas Bob's Avatar
Texas Bob
Replaced everything on the A/C system at a local shop three years ago this month. Took to another shop in town and they say the compressor is leaking and I only have 1 lb. of R134A in the system. They want to replace the compressor with a rebuilt compressor from Global for $295 and labor to replace and recharge will be around $485 (sounds a little high to me). I can get a Denso 471-8121 New Compressor with Clutch from Amazon Prime for $120. They will do the labor for the same price mentioned above. Any advice on the Denso product would be appreciated. Also, any advice on replacing the compressor myself and just having them charge it? The current compressor is a Murray from O'Reilly and is out of warranty. I have done my own A/C work prior to this 2003 Ford. When the sun goes down tonight, I will verify the leak. Thanks for any advice.
Old Sep 14, 2019 | 07:36 PM
tfunk88's Avatar
tfunk88
Removing and replacing the AC compressor on a 6.0 is a pain in the ***. Depending on your perspective $485 for removal/replacement AND recharge may seem like a bargain.
I got a “Factory Air” brand compressor from Advance Auto for $180, which included a new dryer and orifice tube...both of which I think you should replace if you’re replacing the compressor.
It’s been working great, but I’ve only had it in a few months.
Old Sep 14, 2019 | 08:48 PM
john shopes's Avatar
john shopes
I replaced mine with a fomoco and i believe it was from sarasota ford. Ran me about 200.
Old Sep 16, 2019 | 08:34 AM
SmackDaddy's Avatar
SmackDaddy
Getting to that sumbich is the hard part, it’s buried and you pretty much have to remove the radiator, fan, shroud etc to get in there and remove the mounting bolts which are super close quarters with the crossmember.
Old Sep 17, 2019 | 11:24 AM
john shopes
I dont recall removing all that when i did mine. I was doing the whole ac system so i had the fender liner out and i think i pulled the fan shroud. I know i didnt pull the radiator or fan.
Old Sep 17, 2019 | 01:45 PM
tfunk88's Avatar
tfunk88
I pulled the fender liner and loosened the shroud, but didn’t remove radiator or fan. Although that would def give you some more room
Old Sep 17, 2019 | 03:29 PM
Ford.Dude's Avatar
Ford.Dude
I did as John and trunk. Removed the inner fender. The bolts are in a crazy tight spot. After fighting that thing for hrs I went to the parts store and picked up this wrench. Super easy job with it.
Old Sep 17, 2019 | 11:17 PM
Fuzzpuss's Avatar
Fuzzpuss
Whatever you do, stay as far away as you can from Four Seasons brand compressors.
jhruzek
May 19, 2015 04:39 PM
Bubba Jones
1978 - 1996 Big Bronco
Apr 10, 2011 11:42 PM
NeXtras
15
Mar 25, 2007 11:09 PM
smandzak
May 26, 2004 04:13 PM
RangerMikey2u
Jul 14, 2003 08:16 PM
