Siezed Compressor
Old Mar 24, 2007 | 01:44 PM
NeXtras's Avatar
NeXtras
Siezed Compressor
So i went to go turn my a/c on, compressor starts grinding and truck stalls out. Popped the hood, its siezed. My question is, how hard is it to replace it yourself and how much can a compressor cost? I know you would have to drain the system and technicaly you cant do it yourself cause it is considered hazardous waste. I really dont wanna spend the money on labor if its something i can do myself. Also, if i can't do it myself, is it labor intensive? Thanks guys
-Brian
Old Mar 24, 2007 | 02:36 PM
ReAX's Avatar
ReAX
It shouldn't be that bad, esp considering you leaked out all of r12. It should be a simple matter of disconnecting two lines and one wiring harness, then ubolting and replacing the pump.
New pumps can run upwards of $600, and do not have refigerenat oil in them. Also when replacing a compressor it's recommend that your also replace the oriface tube and accumulator.
Old Mar 24, 2007 | 03:26 PM
NeXtras's Avatar
NeXtras
leaked out r12? whats that? and on LMC truck, the pumps seem to be under 300... i cant find one for 1994, i may call a ford deaership and ask them
Old Mar 24, 2007 | 03:43 PM
ReAX's Avatar
ReAX
Your truck should have been charged with R12 refridgerant. If it all leaks out, there is no reason for you not replace the parts yourself and refill/upgrade to r134a.
57120 COMPRESSOR RMFG 315.40
58120C TAS NEW A/C COMPRESSOR 297.33
YCC-112-RM F2UZ19V703FARM \COMPRESSOR/CLUTC 297.98
YC-189 F77Z19703AB \NEW COMPRESSOR 335.98
010394 NEW COMP W/CLUTCH 403.82
Old Mar 24, 2007 | 04:33 PM
NeXtras's Avatar
NeXtras
it didnt leak out, the compressor is just seized... i just need to know if it is an easy do-it-yoursely projects
Old Mar 24, 2007 | 04:37 PM
ReAX's Avatar
ReAX
Yes it is.
Old Mar 24, 2007 | 04:39 PM
NeXtras's Avatar
NeXtras
ok, cause i really dont wanna pay to have a mechanic fix it, way too much money... so thanks for your help
Old Mar 24, 2007 | 05:36 PM
quicklook2's Avatar
quicklook2
your truck has r134a in it if is a 1994.
how do you get the charge out safely is still the question.
reax, are all those comp. prices from same place?
Old Mar 24, 2007 | 07:41 PM
jk89cat's Avatar
jk89cat
go withthe ford brand new unit its worth the cost, and like the other post said, you will be changingthe accumulator and the orfice tube, and it probally wouldnt hurt to have the condenser and evaperator professionally cleaned/flushed
Old Mar 24, 2007 | 07:48 PM
ReAX's Avatar
ReAX
They are all my suggested retail prices, but they are all from the same distributor/ multiple manufactures.
Old Mar 24, 2007 | 10:20 PM
NeXtras's Avatar
NeXtras
thanks for all the input... im gunna take the cheapest way out... in a sense tho, i am gunna get OEM ford i believe... gutta call York Ford monday and see what they can tell me
Old Mar 24, 2007 | 10:45 PM
unixadm's Avatar
unixadm
Just an FYI, but when a compressor locks up it can introduce metal and foreign debris into the system. That can clog up the condenser among other things. I had a compressor lockup on a 1995 Caprice LT1 and it ruined my compressor at the same time. We spent a lot of time cleaning the lines before replacing the compressor. I also had to get a new condenser, so it may not be plug and play.
Old Mar 25, 2007 | 12:18 PM
NeXtras's Avatar
NeXtras
i unplugged the compressor at the moment anyways, so it cant acidentally be tripped.... if there was metal in the system i probably would know by now... thanks tho
Old Mar 25, 2007 | 10:32 PM
jk89cat's Avatar
jk89cat
no you actually may not , the orfice collects alot , but other stuff still gets thru
Old Mar 25, 2007 | 10:50 PM
jroehl's Avatar
jroehl
If you're just going to vent the refrigerant to the environment, then, yes, replacing the compressor is easy. Getting it to work properly again on your own is not. I have to go with Unixadm, too--you more than likely have metal in your lines. It doesn't take much for a compressor that's 13+ years old to shed some metal into the refrigerant and start wreaking havoc elsewhere. You're probably looking at replacing the compressor, lines, condensor and maybe a few other miscellaneous parts, plus you'd have to have an A/C shop pull a vacuum, add the right oil in the right amount, then add the correct amount of refrigerant--these things can't be done by a home mechanic unless he has all the right (and expensive) tools, gauges and pumps.
Start saving your pennies...I'd be surprised if you got into a reliable, working A/C for less than about $750.
BTDT, learned the hard way.
Jason
