VSS Connector Question
Old Sep 9, 2019 | 11:23 AM
Indy50's Avatar
Indy50
In the middle of troubleshooting an Intermittent Cruise Control not working issue, have already replaced the Brake Pressure Deactivation Switch and Pigtail on the master cylinder, now looking at the VSS on the rear differential since its an input to the circuit. I noticed that when I took off the VSS connector, the top of it rotated in the base a little, it kinda looks like the connector might be designed to rotate to accomodate axle movement. Is it supposed to do that?
I see that RiffRaff diesel sells the Motorcraft VSS Pigtail kit so didnt know if its a common problem.
Thanks in advance for the help.
Rick Andriashek
Jun 17, 2019 04:35 AM
Music250
Dec 1, 2018 01:53 PM
JWC64
Jun 18, 2015 07:38 AM
delcamm
1997 - 2003 F150
May 4, 2013 06:46 PM
spongecop
Apr 10, 2012 11:36 AM
