Hi
My cruise control doesn't work. I've just had the van for two weeks. It's a 1993 E250 with 351w engine...
My searches on the big interweb tell me, that in 90 per cent of the cases, it's the brake pressure switch, that's the culprit. BUT - there's no brake pressure switch on the master brake cylinder. But where is it then...? I'm a bit stomped. It's RABS, and both the speedometer and the rear ABS is working great (testet the latter)...
I've checked the fuses, the switches on the steering wheel, testet the actuator, checked the connection on the throttle... All is well...
In short (a bit late): If the brake pressure switch isn't on the master brake cylinder - where is it then...??
Help!
Thx in advance
Lars from Denmark
Reason: Shortening the post
