351w replacement
Old Oct 7, 2003 | 08:04 PM
otis-bunny's Avatar
otis-bunny
351w replacement
which engines and year can i put in my 84 150 4x4 without making changes? are there any? any help apperciated. thanks jack
Old Oct 7, 2003 | 08:53 PM
jwtaylor's Avatar
jwtaylor
Quite frankly any 351 engine would work, go with a 94 + (F4TE engine code) this will give you the roller cam option. Then swap over your timing cover forward and your intake up and your good to go, don't forget to throw on the fuel pump eccentric. If you cannot find a 94+ or care to then any above 84+ as they use a one piece rear main seal which you should have, a little better than a two piece and easier to change if that is no concern then any 351 will work. Hope this helps
Old Oct 8, 2003 | 07:01 PM
otis-bunny's Avatar
otis-bunny
thanks alot for your help. i need to start looking mine is making noise. jack
Ragger
2004 - 2008 F150
Sep 16, 2009 03:49 PM
FX4 5.4
Apr 10, 2009 09:38 PM
BIG-BAD-794X4
Offroad & 4x4
25
Feb 11, 2006 08:00 AM
SKIRYDR
Jun 7, 2004 10:12 AM
