fuel filter base pump supply fitting
Old Sep 7, 2019 | 07:34 PM
catfish101's Avatar
catfish101
Hello everyone, Been awhile since I have been on.
Does anyone have a source the the fitting on the filter base where the supply line to the pump and the bleed line hooks up? It's the elbow with a nipple made on it.
Old Sep 7, 2019 | 07:59 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
If you are looking for the Olive seal fittings .... https://www.mcmaster.com/vibration-r...-tube-fittings
Old Sep 7, 2019 | 08:04 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
you probably have an older style right ??
Old Sep 7, 2019 | 08:09 PM
catfish101's Avatar
catfish101
Yeah, the older version. The base has just the in and out and a port for the shrader valve. A lot of guys just plug off or put a fitting in that doesn't have the bleed/over flow line that goes to the return lines system. I am switching my 92 over to the old base but I am missing the elbow with the bleed line. I like having the bleed line on. It keeps any air from being forced into the pump. Thanks
Old Sep 7, 2019 | 08:13 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
you can get the small Nipples from the same Site I posted and then drill the elbow and make one
But I don't off hand have a source for the OEM part ;(
Old Sep 7, 2019 | 08:20 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
IF you needed a check Valve I posted the PN for it and I also posted a link to one that could work =====>>> https://www.ford-trucks.com/forums/1...-question.html
Old Sep 7, 2019 | 08:53 PM
DarkOverCast's Avatar
DarkOverCast
That was the exact reason these engines were originally designed with that in there, it makes priming a ton easier if you run out of fuel.
However due to leaky return caps letting the supply drain back to the tank through that little hose it got a bad rep and they said to block it through a tsb.
Its your rig so I definitely say go with what you think will work best for you. I doubt that fitting is still available, ebay may have one. If not a junkyard will if you can find a 6.9
Old Sep 7, 2019 | 09:15 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
right and after the TSB ford started using a check valve instead of just an orifice to solve the issue. I just researched all this not too long ago too
Old Sep 7, 2019 | 09:48 PM
catfish101's Avatar
catfish101
I wondered if it was still made. The IH number for the base was 1801129C1. I came across the entire base plus fittings a little while back but can't remember where or how I found it. It wasn't that long ago. It was with new fittings. I blew it off because I have a base. I will get with my navistar dealer and see what my parts guy can find.
@ lonestar. I did consider making one or putting in a T and tweeking my supply line.
A lot of trouble to save 12 bucks on a filter. lol.. I have switched my 94 over to the old base so its less filters to keep on the shelf.
Old Sep 7, 2019 | 10:26 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
there is a hand full of the complete heads on Fleabay but they pretty proud of em... but I haven't seen any of the inlet fittings for some time now.
https://www.ebay.com/itm/OEM-Genuine...C/113805235567 <<<==== just an example
Old Sep 7, 2019 | 11:27 PM
Charmalu's Avatar
Charmalu
Ya know I just might have a couple of those elbow`s with the bleed line fitting.
I changed the hard line to the IP to push lock hose, changed the fitting on the
IP also.
If you send me your info I will mail you one of those elbow fittings....Now where did
I put those fittings...?
\Charlie
Old Sep 8, 2019 | 12:07 PM
catfish101's Avatar
catfish101
I have been digging around too. I have some Pushlok hose. That is a good idea. Best all around hose ever made.
Arnold Kenyon
15
Jan 27, 2021 12:50 AM
rockittsled
Feb 20, 2014 09:13 PM
robjs111
Jul 18, 2008 06:31 AM
killerkjn
Nov 3, 2005 02:58 AM
Motorcraftsman
May 11, 2000 07:45 AM
