Here's what I'd do. Charge battery overnight and start her up. Measure voltage across batt. Should be like 13-14v. If lower suspect alternator. Pull positive terminal from battery while running, if it dies, then ALT is probably bad.
Next, check all ground wire connections. Your coil is probably good. I am betting on bad charging system or cap/rotor/plug wires first.
NEVER NEVER NEVER do this!
Back in the old days that was 1 way to check but now days you can cause all kinds of badness!
It maybe ok on our trucks but it is best not to get into the habit of doing this.
A cheap VOM from HF will work to measure battery voltage and you can use it for other things on the truck too. http://www.harborfreight.com/7-funct...ter-63759.html
They have better ones but for $7 if you use it 1 time and toss it no big deal.
Think I would go for a $25 one if it was going to be my only meter.
They also have battery chargers too.
Dave ----
Just to confirm I have a 1g alternator and a voltage regulator. Visually the regulator looks like poop. Going to try to follow the process first and do the tests.
That being said I see 2 options for replacement voltage regulators. Do I get a mechanical or electronic if that’s the issue?
No, I would avoid a mechanical regulator. External regulators went the way of the dodo bird, but if you're going to use an alternator that requires one, solid state is what you want.
I was I was bored yesterday and ripped out the alternator and regulator. Lol
I figured since I can replace both for less than $100 I would do it. However I probably won’t have a chance to pick up and install new ones until Friday. If I were betting I’d say this is the issue. Lots of other small clues seem to support charging issue.
Will update later this week. Will probably do tune up after that.
The following is meant in the kindest manner possible, but did you grow up in a house under the power lines? If not under, in very close vicinity?
Even if your charging system is not up to snuff, there's no guarantee the alternator or regulator is the problem. It could be a bad cable. It could be a bad ground. These and many other items are all part of the charging system.
We don't even know if low voltage is causing the rough running and stalling. It was just a reasonable guess and super easy to rule out in mere minutes after charging the battery and testing with a voltmeter. Free, too, if you can borrow the tools. Cheap and easy, that's me, and proud of it!
Don't just rush out and replace the most expensive parts in hopes of a fix, especially when the troubleshooting is so simple to do.
I’m with you and get the thinking. Thanks for being gentle. I’m just having fun learning about this stuff and taking things apart. I guess it’s a blossoming hobby. Golf season is coming to a close and for what I would pay for a new sand wedge or round of golf get me pretty far in parts with this truck. Haha. I wanna get this thing to the point where I can drive it with confidence. So I don’t mind spending a few hundred bucks all in to replace most of the easy to get to parts of the ignition and charging system along with a tune up. If that doesn’t do it I’m sure we can narrow it down.
Anyway, upon inspection wires and connections all looked ok.
Before you rip anything else out give us a decent head start on which parts on next on the block, some replacement parts are notorious for being junk and the old working part in your truck is probably the better of the two.
So far he’s been limiting himself to only everything forward of the firewall, aft of the grill, and between the left and right fenders.
Ha! If it makes you all feel better I was going to test things out one part at a time starting with alternator. Easy enough to plug original regulator in. I want to know what the exact culprit is myself.
I also have a noticeable exhaust leak at the manifold in passenger side. Looks like gasket is gone in one area. That would explain why that side is so loud. Hah. Would this have anything to do with symptoms? Don’t think so but figured I’d throw it out there. Pic below... not something I want to try to tackle at the moment. Any way to seal it off without digging in deep for temporary fix?
OK so this afternoon I changed out the alternator and the regulator. I did them one at a time and neither had an effect on how it was running. At least in my drive away. Low idle, stalling, struggling. Still felt very weak but I did notice as I gave it a few RPMs the gauge for the battery actually responded more than it ever has by moving the needle up. Previously that gauge just sort of bounced around randomly.
Disappointing! I really thought she would come back to life with these new parts. That being said I didn’t get a chance to charge the battery or anything like that but I’m not sure how that could be an issue since it fired right up. Like I said I did double check the wiring and everything looked fine to me.
Do we think there’s more to this charging system story or onto the tuneup and investigate spark issue further? If it makes you all feel better I did just purchase a multi-meter and battery charger but I they won't come for a few days.
Okay, the joke is over. Chris, Matthew, Dave 1 or Dave 2? Which one of you is behind all this? Very funny, you really had me going. A new guy signs up with an apparently simple issue and then proceeds to basically do the opposite of anything I might suggest. Skips the easy preliminary stuff, does the expensive hard stuff, and so on.
I gotta give you guys credit. You had me hook, line, and sinker. But I'm on to you guys now. Time to fess up and take a bow.
If the motor turned over and started on its own, no jumper cables, then charging is not a cause for running ruff.
Have you pulled the plugs yet to see what they look like?
Dave ----
Dave ----
I have not. I figured that was next.
I wouldnt say say anything I’ve done has been hard or really expensive. I apologize for skipping a few steps. Like I said I did purchase some of those things suggested for the future.
Coach, its like somebody sees the Doctor with a sore throat and you go ahead and replace their knees. Not necessarily the best route. Your current troubles (no pun) are probably vacuum leak related, dirty carburetor or due to general out of tune engine.
