Dome light
Old Sep 5, 2019 | 07:07 AM
Brian1950F4's Avatar
Brian1950F4
Dome light
Does anyone have a picture of where the dome light is supposed to be installed in my 48 F3. Thanks
Old Sep 5, 2019 | 07:31 AM
fordf348's Avatar
fordf348
I dont think a 48 F-3 had a dome light
Old Sep 5, 2019 | 08:22 AM
FortyNiner's Avatar
FortyNiner
Correct. No dome lights in the 48-50s.
Old Sep 5, 2019 | 09:38 AM
52 Merc's Avatar
52 Merc
The 51-2 models with the deluxe interior option, or "Extra Cab" had a dome light as part of the option package. It was placed above the rear window, as shown here.
Old Sep 5, 2019 | 02:46 PM
Brian1950F4
Dome light
That must be the one that shows up in the catalogs then. It would explain why there was not a wire for it.
Old Sep 5, 2019 | 02:49 PM
chriscris's Avatar
chriscris
The 48-50 Canadian models had them. I have a spare if you need one.
Old Sep 5, 2019 | 08:26 PM
abe's Avatar
abe
Slight hijack here:
Question for you 48-52 guys. Does anyone reproduce the thermacoustic headliner for 48-52 trucks. You know a headliner with the perforated holes. There are none made for the 53-56 trucks which came with the Deluxe Cabs (53&54) and the Custom Cabs (55&56).
As a matter of fact the Standard Cab style cardboard headliner reproductions are a poor facsimile of the original. The originals had a grain pattern in the cardboard. The repops are simply gray painted cardboard.
Old Sep 5, 2019 | 08:40 PM
Brian1950F4
Thank you. I actually just purchased one since I was going to attempt to put in a headliner. I checked the 3 trucks I have here and none of them had one to use as a location.
Old Sep 5, 2019 | 08:54 PM
52 Merc's Avatar
52 Merc
Originally Posted by abe
Slight hijack here:
As far as I know, no. I've never seen one. I've often thought about how one could make the perforations. Spend 3 days with an awl very carefully, rolling pin with tacks stuck to it...hmmm.
Old Sep 5, 2019 | 09:01 PM
abe's Avatar
abe
Both my trucks are Standard Cabs. I kept the original headliner in my 55 even though it has a crack on the passenger side because I didn't want the plain looking repop. If my 54 were a Deluxe Model I'd be ticked since they don't make the perforated kind.
Old Sep 6, 2019 | 06:39 AM
joezzz's Avatar
joezzz
lI was able to purchase a cardboard style headliner. It is black. The fit, with a little work should work out sufficently.
I will have to look back into my receipts to find what supplier purchased from.
Dome light; Wiring diagrams show a light located in the middle of the roof of cab. The wire running down the driver's side windshield post.
Old Sep 6, 2019 | 08:14 AM
Jersey devil's Avatar
Jersey devil
On the 51 52 extra cabs the dome light wiring goes from the drivers side door jam button to the passengers side door jam button up to the dome light switch at the dome light.
hope this helps,
tom
Old Sep 6, 2019 | 09:48 AM
joezzz's Avatar
joezzz
The dome light that I located had its own on/off switch built into the fixture..............no does not look like someone's add-on.
Old Sep 6, 2019 | 10:04 AM
52 Merc's Avatar
52 Merc
The original 51-2 dome light wiring was routed like Tom said. You can see the wires in my pic above. The wires ran from left to right under the dash, then over the passenger door. Same with the fuel sender wire. The door jamb switches are mentioned in the Extra Cab ad. That light also had an on-off switch as part of the lamp assembly in addition to the door jamb switches, and it, too, can be seen in the pic, right below the lamp. You could turn it on without having to open a door from there.
Rusty_S
Aug 26, 2015 08:51 PM
Bigbruce
WTB - Parts & other
May 27, 2012 03:15 PM
drifty4
2004 - 2008 F150
Oct 15, 2007 07:14 PM
