Mild 6.0 build recommendations
Truck in question is an 06 F250 with 111k on it. Right now it's all stock except for coolant filter, egr delete, and a 4" turbo back exhaust and SCT tuner with custom tunes. I did stud the engine but only had 3 days to complete the job as it was my only truck at the time and the heads were warped when I put then back on the vehicle. That lasted about a year and started blowing coolant out of the degas bottle again. So it's been sitting for 5 years and now I wanna put some money into it.
Itll just be my fun truck and may see light towing but i have a dually now that will do most of that. I would like recommendations on injector sizing, turbo upgrade, regulated return or not, should I get the heads oringed after getting them tried or just get them trued? What else would be recommended with the cab removed?
Thanks in advance
Bill
SCT X4 tuner, Gearhead custom tunes, UCF O-ringed heads, ARP 2000 studs, Ultra FICM/Atlas 40, Holder’s 175/30’s, Driven Diesel regulated return, 6.7L fuel pump/ custom fuel system, Powermax/RiffRaff billet wheel, Dieselsite EGR delete, CCV mod, S&B Stage 2 air filter, Dieselsite Adrenaline HPOP, 4" pipe/5” black MBRP tip, RiffRaff boots, CFS HD intercooler, MBRP Y pipe, DieselSite coolant/trans filter, Mishimoto alum radiator/Fumoto drain, 7.3 fan clutch mod, Dieselsite coolant return, 6.4 trans filter/PML pan, MTS shift solenoid upgrade, 6.4 Mean Green starter, Leece Neville 230amp alternator/full cable upgrade, Optima Red tops, updated engine/FICM harness/Tesla heat tape, X/Mod C’s, 2” shackles and hangers, 4” tapered rear blocks, Bilstein 5100 shocks, 305/70R18 Cooper Discoverer STT Pros/Weld 18x10’s, Warn manual locking hubs, Motorcraft master cylinder, Powerstop rotors/pads, Russell braided stainless steel brake lines, Superlift/Bilstein dual steering stabilizers, Rear Hellwig BigRig sway bar, ‘08 mirrors, Raptor LED headlights, dual recessed 12" Oznium LED bars, Opt7 interior LEDs, ELM327/TorquePro/Joying Android head, BumperDude full replacement grill guard.
