5.8ltr ignition issues
Old Sep 2, 2019 | 06:31 PM
Johnnyab's Avatar
Johnnyab
I have a 1989 F-150 lariat 5.8ltr. I’ve owned it for 4 months, it’s always idled relatively high, but recently it’s been missing really bad, and it’s died a couple of times in the last week. Through research online (some here) I decided to replace the ignition control module. I unplugged the connector, marked the distributors location, loosened bolt holding down the distributor, turned it about1/4 turn. Used 5.5mm deep socket to remove old ICM, greased, and installed new, moved back to original position, hooked back up.... truck won’t start! WTF DID I DO WRONG?!?! Any advice is appreciated.
Old Sep 2, 2019 | 07:30 PM
88n94's Avatar
88n94
Maybe the new ICM is defective. Might be simplest to reinstall the old ICM and see if it starts.
Old Sep 2, 2019 | 08:03 PM
Johnnyab's Avatar
Johnnyab
I forgot to mention, that was the first thing I did after it wouldn’t start.
Old Sep 3, 2019 | 07:18 AM
subford's Avatar
subford
Pull out the SPOUT and see if it will start.
tylert1976
30
Dec 8, 2012 01:07 PM
73FordF100
25
Jun 12, 2011 11:51 AM
1988ford
May 4, 2003 10:14 PM
Raul
Mar 1, 2002 09:01 PM
FrankM
Oct 6, 1999 05:54 PM
