ECM data base
Old Sep 2, 2019 | 01:37 PM
daltonjamesadams's Avatar
daltonjamesadams
ECM data base
I am wanting to have a spare ecm on hand for our 93 5.0 aod. My parts truck is a 92 5.8 E4OD. I do not think they will swap, but would like to know if there is a data base where i can run the numbers to see if there is a match.
Thanks
Old Sep 3, 2019 | 02:00 PM
wwhite's Avatar
wwhite
Post the catch/strategy/code which is located on the Electronic Engine Control (EEC).
If your truck(s) have original paint, inside the door jam, somewhere, sometimes located on front of drivers door jam near windshield post while door open, there will be a little sticker with 4, sometimes 5 digits. Something like (KID2, CBAZA, C3P2, etc..)
It is possible that the E4OD EEC-IV will work with AOD, just not the other way around. More research will be needed.
Old Sep 3, 2019 | 02:07 PM
wwhite's Avatar
wwhite
You will still need the code, and here are a couple places to start:
https://www.tweecer.com/ccode/
Strategies
Supported Vehicles
There are many more...
Old Sep 3, 2019 | 04:06 PM
Eddiec1564's Avatar
Eddiec1564
It will run the engine fine, but the ECU will throw all codes for the missing E4OD tranny. I ran my 89 F250 I6/AOD with and 92 I6 E4OD ECU. I got tired of too many codes and finaly found a correct automatic ECU.
lio45
15
Feb 20, 2018 06:04 PM
Keith Wells
Aug 9, 2017 05:24 AM
KaoticCreations
Jan 24, 2012 04:42 PM
C.W
Oct 5, 2008 03:33 PM
wozxxx86
Jan 19, 2007 05:18 PM
