Carb problem
Old Aug 26, 2019 | 04:09 PM
kfouts2's Avatar
kfouts2
Carb problem
I just acquired a 1978 F600 with a 361 industrial motor. The carb was rebuilt and runs great. However, when you start the engine it coughs and sputters. You cannot take off or the engine will die. But, if
you let it warm up it runs like new.
The choke, governor, etc. have all been checked and appear properly adjusted but something is very wrong.
Free pizza to whoever figures this out.
Thanks.
ken
Old Aug 26, 2019 | 04:39 PM
fordguy2100's Avatar
fordguy2100
The choke seems adjusted properly.... but is it working properly? This sounds exactly like not having a proper working choke
Old Aug 26, 2019 | 04:54 PM
Ozzie H.'s Avatar
Ozzie H.
If everything is great after it warms up, I'll second the comment that it is likely something with the choke. I could never get my automatic choke to work correctly; hence, I converted to a manual choke & throttle.
Old Aug 26, 2019 | 05:52 PM
kfouts2's Avatar
kfouts2
Well, it is back to the choke. The promise of free pizza still stands.
Thanks.
Old Aug 26, 2019 | 07:55 PM
ranger140892's Avatar
ranger140892
Grumpy goat
That's an easy diagnosis. It's lean on cold start (which it should be) but the choke is not compensating enough. Manual choke cures that issue.
Old Aug 27, 2019 | 08:04 AM
ranger140892
Grumpy goat
Pull the air cleaner off. Have someone else crank the truck, while you manipulate the choke plate by hand. If you can get it to run correctly, then there's the answer.
Old Aug 27, 2019 | 09:13 AM
Tedster9's Avatar
Tedster9
Make sure compression is good, and no vacuum leaks, and ignition timing is running at spec. A mechanic's vacuum gauge is the only way to fly for engine diagnostics and tuning. If engine won't pull 18" to 20" steady at idle, find out why. Carb calibration and tuning is basically impossible if there are any problems elsewhere, they are completely dependent on a strong engine manifold vacuum.
A carb choke doesn't really work the way people sometimes think, they don't block the air off so much as they increase the velocity of the air that does flow, and consequently extra fuel is "pulled" from the well for cold enrichment. Hardly any air flows through a carb at idle, it needs the manifold vacuum to atomize the fuel. So anything that buggers that up, incorrect ignition timing, late valve timing, vacuum leaks, will cause problems. "90 Per Cent of Carb Problems are Ignition Related".
Old Aug 27, 2019 | 10:36 AM
kfouts2's Avatar
kfouts2
I am very glad to have joined this forum. I feel much better about tackling this beast Saturday. Will let you know what the outcome is soon. Pizza for ALL!!
Thanks for the great advice.
Ken
Old Aug 27, 2019 | 10:52 AM
ranger140892
Grumpy goat
Ken
Please don't send pizza here! My butt is wide enough. Just get your truck fixed.
Old Aug 27, 2019 | 10:54 AM
kfouts2's Avatar
kfouts2
Does anyone want Mike's share of the pizza?
Old Aug 27, 2019 | 10:59 AM
ranger140892
Grumpy goat
Dangit!!!!!!!!
Old Aug 27, 2019 | 05:21 PM
LARIAT 85's Avatar
LARIAT 85
Thanks.
ken
It sounds like your choke isn't working correctly. If you are running a stock carburetor, you should have a thermostatic choke with two tubes. If you have an aftermarket carburetor, you would have a fully electric choke with two wires.
What is your starting procedure? If driven daily, your truck should only require *one* pump to start a cold engine. A warm engine wouldn't even need that. You should never have to "pump" the gas to start the engine.
The next time your engine is cold. pump the gas once. Then, remove the air cleaner lid and verify that the choke plate is completely closed. If it isn't, it's not set correctly.
If that checks out, start the engine, but do not pump the gas pedal. It should fire off immediately. When the engine starts, the choke plate should crack open just a little and the engine RPM should be higher than normal. If it doesn't do that, something isn't set correctly.
As the engine warms up, the choke plate should gradually open. At full operating temperature, the choke plate should be completely open.
Old Aug 27, 2019 | 05:56 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
However, when you start the engine it coughs and sputters. You cannot take off or the engine will die. But, if you let it warm up it runs like new.
1978 F600 w/a 361 would have a Holley 4V carb. See pic below:
The 361 is not an industrial engine, per se...it's an FT engine. It was an option for 1964/78 500 and larger series trucks.
FT's also available 1964/78: 330 2V Medium Duty, 330 2V Heavy Duty, 391 4V
btw: In pic, 389 is a detuned for smog 391.
Old Aug 27, 2019 | 06:09 PM
kfouts2's Avatar
kfouts2
Great advice. Thank you! I feel like I owe more than a pizza. 🙂
Old Aug 27, 2019 | 06:26 PM
NumberDummy
You could send it "Air Fouts" to whoever wanted it.
Dan Fouts, former QB of the San Diego Chargers.
Reed_50
Feb 13, 2011 10:54 PM
51dueller
Oct 9, 2004 12:29 PM
amelchio
Aug 7, 2003 09:24 PM
deondanno
Jul 14, 2002 03:40 PM
