58' carb question
Old Aug 5, 2003 | 06:27 PM
amelchio's Avatar
amelchio
58' carb question
I have a 223 with a 1 barrel Holley Carb. Sometimes I lose power getting the truck off the line. It usually happens on a hill or when hauling a load. I've been told it could be an accelerator pump problem. However, before I take apart the carb I was wondering if I should just bolt on a new 2 barrel carb, maybe one with an automatic choke? Will that help the performance without killing gas mileage?
Old Aug 5, 2003 | 06:29 PM
DS02F250's Avatar
DS02F250
58' carb question
yep, do the 2-barrel w/ auto choke. check your timing too after installing the 2-bbl.
Daryl
Old Aug 5, 2003 | 10:18 PM
MercM47's Avatar
MercM47
58' carb question
Had a similar problem. Bought a new carb and it got worse. Had the original carb rebuilt by an expert and she now runs like a champion.
Old Aug 6, 2003 | 12:31 AM
laynrubber's Avatar
laynrubber
58' carb question
Tell me more about these 2 barrel carbs.
I rebuilt the single barrel Holley for my 6 and it runs way better now, no flooding, idles great, no external leaks but the float is real touchy and i have had to adjust it a couple times.
I thought a carter 1 barrel would fit but my interest is stirred with a 2 barrel
Old Aug 6, 2003 | 01:03 AM
MercM47's Avatar
MercM47
58' carb question
a lot of it has to do with the carbs cfm and engine requirments. Holley has a great tech section that is in depth at www.holley.com
Once you get the floats and jets locked in you should be good for years
Old Aug 7, 2003 | 08:48 PM
bhabben's Avatar
bhabben
58' carb question
amelchio,
Don't pass judgement on that OEM holley before fixing it. It's a good economical carb, used on many other engines besides Ford 223's. It's main downfall is that they are small (which is why Fenton made 2-1bbl intakes, etc.)
Adios,
Brett
Old Aug 7, 2003 | 09:24 PM
lfleischer's Avatar
lfleischer
58' carb question
I had my Holley rebuilt and all works well. Rebuild kits may not be enough as some areas of the carb may need to be rebushed. Try Red Bow restorations. They did a GREAT job on mine!
http://www.redbowrestorations.com/contact.htm
sweetlou1
17
Mar 17, 2013 08:18 PM
dvandervossen
WTB - Parts & other
Nov 29, 2012 11:02 PM
80 f-150
Sep 5, 2011 11:47 PM
Lumpy78
May 4, 2010 11:25 PM
blazer350
May 18, 2008 07:11 AM
