Painting FX4 Fender Flares
Old Aug 26, 2019 | 01:47 PM
smokewagun's Avatar
smokewagun
My son wants black flares on his 2011 FX4. His are the rough finish molded plastic flares on dark gray. It seems trying to sand smooth would be a forever chore and lead to poor results. Any recommendations? Paint and prep recommendations for good adhesion? I was wondering about Krylon plastic paint. Thoughts? Thanks!
Smoke
Old Aug 28, 2019 | 09:22 AM
JKBrad's Avatar
JKBrad
I’ve used Krylon Fusion and Rustoleum paint for plastic, both with good results.
I had a 2001 XJ Cherokee a few years ago and all of the black plastic turned a nasty grey. I cleaned all of the parts I wanted to paint with a degreaser, then isopropyl alcohol. I carefully masked the parts that could not be removed, then sprayed the paint. It looked great. A nice satin black. Lasted until it was sold a few years later. One part had to be redone due to it getting scratched a few months later. This was done with the Rustoleum product.
This type of paint chemically bonds with the plastic, so the results are quite good.
Old Aug 30, 2019 | 08:25 AM
Siberexpress's Avatar
Siberexpress
Actually Smoothing them out is not as bad a you think, you scuff them up with a Maroon Scotch Brite Pad then put 2 heavy coats of primer on with adhesion promoter in the first coat then sand the primer smooth with some 200 then 600. You barely get into the plastic all the sanding is just primer. I did the rear window surround on my 2003 F150
Old Aug 30, 2019 | 09:17 AM
smokewagun's Avatar
smokewagun
Thanks guys. I’ll give it a shot with him. We’re doing the wheels this weekend. They are the factory grey plastic laminated FX4 wheels (20”). I’m actually thinking about equipment enamel. Durable, but a quick repair if damaged. Already have the scotch-brites and sand paper.
Old Dec 31, 2019 | 12:08 PM
FordCommander's Avatar
FordCommander
Great thread with lots of helpful info. I was thinking about getting some fender flares and having them painted.
Old Jan 1, 2020 | 04:02 PM
2jhanna's Avatar
2jhanna
I have a 2002 Jeep Wrangler,( the TJ years, 1997-2006), have a lot of plastic, that turns gray. Fender flares, bumper ends, etc.
Its very common in that world to use the krylon spray. I've done mine in the satin black. Has looked good for years.
Gundown64
2004 - 2008 F150
Jan 29, 2012 09:31 PM
MCDavis
2004 - 2008 F150
37
Nov 4, 2010 07:42 PM
MCDavis
2004 - 2008 F150
16
Sep 21, 2010 07:04 PM
patrickke
Feb 13, 2009 06:33 PM
06BLK-F150
2004 - 2008 F150
Mar 28, 2007 03:20 PM
