Sponsored by: Real Truck
2003 Mirror Upgrade Help
Old Aug 25, 2019 | 11:12 AM
JH250's Avatar
JH250
Hi, I'm a newbie here. I just upgraded my mirrors on my 2003 F250 6.0L Centennial Edition. I upgraded them with mirrors from a 2013 Harley Edition F250.Everything fits great, and they look great. My problem is the flat plugs do not match up. I have 7 wires on my original plug, the new ones have 9 wires. I know there are pigtails for a round 4 pin to a flat plug, but is there a pigtail out there for a flat to fit between these model years? Both old and new mirrors are power and heated, and have the turn signals on them, they are also manual fold and extend.Any help would be greatly appreciated.
Old Aug 26, 2019 | 10:47 AM
2004 F450's Avatar
2004 F450
Is this what your looking for?
https://www.1aauto.com/ford-mirror-w...=934701&y=2003
Old Aug 26, 2019 | 10:51 AM
JH250's Avatar
JH250
No, it is not. I do not have the round plugs. I have already searched 1AAuto for the flat plug to flat plug.
Thank you anyway.
Originally Posted by 2004 F450
Old Aug 26, 2019 | 12:20 PM
brian42's Avatar
brian42
Veteran: Navy
You have several options:
1. Find a donor mirror with flat plug. You will have to cut than one off, push the pins out of the round one off the mirror, then wire the flat plug to the '13 mirror so you can connect it (pin removal tools are relatively inexpensive).
2. The same as #1 but order a flat plug from Ford (I've seen the connector catalog link posted in FTE but don't remember which thread).
3. Cut both plugs off and splice the wires together. This is the easiest and cheapest route but makes it difficult if you want to disconnect the mirror in the future.
Just my .02
Old Aug 26, 2019 | 12:24 PM
JH250's Avatar
JH250
Thanks. I was thinking about splicing them. I don’t have the round plugs at all.
But, the truck set is 7 wires, the mirror set up is 9 wires. Trying to figure out the reason for the two extra wires?
Old Aug 26, 2019 | 01:18 PM
brian42's Avatar
brian42
Veteran: Navy
Are they power folding?
I don't have a pinout for the '08-up mirrors but I'm sure you can find one floating around here somewhere.
I'm not 100% sure of your truck wiring but this is the "template" I had for wire colors/functions for the '03-'07 style mirrors I had:
Black = ground
Brown = clearance lights
White = right turn signal
Green = left turn signal
Black/White tracer = heat
I did find find some info here: https://www.powerstroke.org/forum/6-...onversion.html
Not sure if this picture helps but I found this also:
Old Aug 26, 2019 | 01:26 PM
JH250's Avatar
JH250
Thanks, that will help. I will look at the link you sent as well. And no, the are not power folding or telescoping.
DanielWilson
Aug 5, 2024 06:34 PM
1MrBrian1
Oct 29, 2014 09:03 PM
bergy 2000
Dec 17, 2012 04:30 PM
Kwikkordead
33
Apr 21, 2010 06:49 AM
Bruinzfan
Sep 7, 2003 11:01 AM
