Bad AC compressor or something else?
Old Mar 5, 2017 | 09:38 PM
hardeyf150's Avatar
hardeyf150
Good evening everybody!
New to the forum here and have previously solved issues using threads from here, so it was time to join!
Been having an issue lately with the AC system on my 2010 4.6L F150. The AC system is not working properly and is only blowing air the same temp as outside. In other words, if its 60 degrees in the morning the AC will blow cool, but later in the day its blowing warm. Pushes air no problem, but living in Florida, it's mainly warm air. Compressor clutch is kicking on and off fairly rapidly when on max AC setting (5-10 seconds on, then 5-10 seconds off). Hooked up gauge to low pressure side and the readings were 60psi WITH compressor on, then fell to 30psi when the compressor turns off. Any suggestions on where to start? Haven't done too many AC fixes before, so any ideas would help. Potentially a bad compressor? Overcharged lines? Thanks in advance guys
Jared
Old Mar 6, 2017 | 10:12 AM
rbentnail's Avatar
rbentnail
bad thermistor? https://www.ford-trucks.com/forums/1...-solution.html
Old Mar 6, 2017 | 03:19 PM
projectSHO89's Avatar
projectSHO89
A short-cycling compressor is a sign of low refrigerant about 99% of the time.
Old Mar 6, 2017 | 03:20 PM
projectSHO89
Originally Posted by rbentnail
Different set of symptoms.
Old Mar 6, 2017 | 05:22 PM
Turbo Dog's Avatar
Turbo Dog
You need to know how high the high side pressure is. Once the high pressure goes through an orifice it expands and consumes the heat creating the cool air. And as pointed out earlier, a short cycling compressor usually means the pressure is low.
Old Mar 12, 2017 | 12:51 PM
rbentnail's Avatar
rbentnail
Is it? That's what the thermistor does- cycle the compressor. If it or the plug or wiring is a little wonky it would provide exactly what is happening. It's worth $2.85 or whatever at Radio Shack to jump it out and see what happens isn't it?
Old Mar 12, 2017 | 01:17 PM
projectSHO89
Is it?
Yes, it is different. This thread is for a short-cycling compressor. The other one is for a system that described as "mediocre" due to a software limitation on the evaporator core temperature and describes a way to fool the computer.
If you should happen to understand HOW the system works, you can discern what the difference is. Note that this one works okay in the cool mornings but fails completely during the heat of the day. These are classic symptoms of a severely undercharged system.
No, it doesn't. The thermistor REPORTS the evaporator temperature to the computer when then, based on its programming, makes the decision on how to control the clutch. There is a profound difference that must be understood.
If you want to go to Radio Shack and try a resistor in YOUR truck, go ahead. You'd better hurry, though, most of them will be gone VERY shortly, like 1-3 weeks. They just filed for BK and almost all of them except a couple hundred nationwide will be closing by early April.
Old Mar 13, 2017 | 06:39 PM
Blondie70's Avatar
Blondie70
I think low Freon also. He needs a friend or someone with a set of gauges and a few cans of Freon to help him out. I would only add refrigerant if I could watch the high side at the time to make sure all is working ok. (a manifold with gauges hooked up)
rowekmr
May 22, 2019 12:39 PM
ranger332
2004 - 2008 F150
Oct 6, 2016 07:15 PM
mking_552
Jul 24, 2007 03:07 PM
Bad Company
Mar 28, 2005 11:36 PM
CAlex
23
Mar 14, 2005 06:45 PM
