Sponsored by: Real Truck
Fuel Pump Maybe??
Old Aug 22, 2019 | 06:41 PM
rmo5095's Avatar
rmo5095
Fuel Pump Maybe??
2000 F350 V10, a week ago drove the truck about an hour it was about 90 degrees out, shut the truck off, 30 seconds go by try to start and turns over doesn't start, sounded like it was starving for fuel , tried a few times and nothing, let it sit about twenty minutes fired right up like nothing happened, No stumbling not skipping, nothing, It happened again today except this time would not start at all, havent begun to diagnose yet but, I have had fuel pumps go before and they go out once and thats it, Any thoughts? Thanks.
Old Aug 22, 2019 | 07:03 PM
Just Strokin's Avatar
Just Strokin
Not a gas engine buy but have you pulled codes to see if anything is stored? Lots of times a heat related issue of crank but no start is electrical in nature.
have you bumped the bottom of the tank to see if this is cause the fuel pump to work?
Old Aug 22, 2019 | 09:36 PM
Djosbun's Avatar
Djosbun
If this is strictly a ‘hot no-start’ situation then you probably have a different issue. The first test, which is simple, is to drive the truck and get it to operating temperature. Probably best to just drive around your area and shut it off at home. Immediately try and restart it. If it cranks and doesn’t fire, hold the throttle pedal to the floor and try starting it again. If it starts up fine and continues running, then your problem is a very rich running condition, where the engine is basically flooding itself while running.
Report back and we will go to the next steps.
— Dave
Old Aug 23, 2019 | 05:34 AM
rmo5095's Avatar
rmo5095
No start, no codes, dont here fuel pump running.
jlager
Nov 14, 2012 09:54 AM
howler4x4
Modular V10 (6.8l)
Dec 8, 2010 08:30 AM
01kingranchKY
2004 - 2008 F150
Oct 28, 2010 07:55 PM
shaggin1
Modular V10 (6.8l)
Dec 30, 2009 08:40 PM
Bearscratch
Modular V10 (6.8l)
18
Aug 20, 2009 12:55 PM
