Modular V10 (6.8l)
Intermittent no start - no codes
Old Dec 6, 2010 | 02:54 PM
howler4x4's Avatar
howler4x4
Warm start...
Cranked fast, fired for a sec & died. repeat. Cranked fast, no fire, repeat.
Did that for a while...
No codes. Then it started, ran fine all weekend.
Any ideas?
92K on the V-10
Old Dec 7, 2010 | 09:20 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I'll move this to the V10 forum, but next time it happens, try this:
-While cranking, step on the gas, if it starts and revs it's the idle air controller.
-You may also check your fuel pressure while cranking as your fuel pump may be on it's way out.
Old Dec 7, 2010 | 09:30 AM
howler4x4's Avatar
howler4x4
Thanks Tor !
I did do this, no luck:
I floored it, maybe that's wrong?
Old Dec 7, 2010 | 11:26 AM
krewat's Avatar
krewat
Push the pedal down about one inch, not floored.
Sounds like the fuel pump or pump relay is going though.
Next time it happens and if pushing the go-pedal doesn't help, whack the gas tank with a 2x4. Not very hard, just enough to make it wiggle If it starts up, the fuel pump needs to be replaced.
Old Dec 8, 2010 | 08:30 AM
howler4x4's Avatar
howler4x4
Thanks Krewat!
rssnape
Dec 30, 2014 05:17 PM
Tlid1011
Oct 22, 2014 08:49 PM
howler4x4
Nov 20, 2013 08:46 AM
Paladin921
24
Mar 20, 2011 09:19 AM
scatgo
Aug 29, 2010 07:22 PM
