Headlight switch question
Old Aug 20, 2019 | 09:05 PM
hollygreenf250's Avatar
hollygreenf250
So after the help from some FTE members I replaced the homemade fuses in my fuse panel/junction block with the proper size and found out why the PO had rigged the fuses to not blow, bad headlight switch. Replaced it with a new one from my local parts store. And gained my cab light back, plus no blown fuses when battery hooked up.
Question I have is, is it normal for the instrument cluster lights to go brighter when the **** is turned counter clockwise? (Towards cab light turn on) and dimmer as you turn clockwise. Seems weird to me.
Otherwise switch and fuses fixed all electrical issues.
Thanks in advance!
Old Aug 20, 2019 | 10:06 PM
Tedster9's Avatar
Tedster9
I think that sounds right. Make sure ground and battery cables are fresh, and tightened securely to clean, unpainted metal at frame and block, firewall, etc. This is what roasts light switches to begin with, high resistance, they have pretty long runs of wire to the headlights and stop lights.
Old Aug 21, 2019 | 08:43 AM
AZSCAWPION's Avatar
AZSCAWPION
That is correct.
Old Aug 21, 2019 | 06:31 PM
hollygreenf250
Alrighty thanks for the confirmation!
Cheers
Hutch17
16
Oct 1, 2013 04:11 AM
conoso
Aug 1, 2012 07:49 AM
BIGT94z
May 8, 2010 09:47 AM
alexchavel
Dec 4, 2009 08:09 PM
Hit Man X
Nov 26, 2008 02:23 PM
