6.2L V8 Discuss the 6.2L V8
2017 Engine "Knock" (vids)
Old Aug 26, 2019 | 02:21 PM
DSLTRK60's Avatar
DSLTRK60
Originally Posted by JackalAR
I've definitely been meaning to do just that DSLTRK, we've been busy Mustang shopping. I would agree that the conditions would make one lean toward exhaust manifold leak, but it's definitely a knock from the bottom, center of the engine and not from one side or the other, but sounds do odd things so I wouldn't rule anything out just yet. Was relieved that I couldn't feel the knocking what so ever. Will report back, may dry out enough today to get back under there and check.
Somewhat of a similar story. I had a 2.3l Ranger have the knocking sound when warmed up. Sound seemed to be coming from the top rear of the engine.
Used the stethoscope method and it turned out to be the rear alternator bearing going.
Old Aug 26, 2019 | 03:42 PM
MJAB's Avatar
MJAB
Originally Posted by DSLTRK60
If it's intermittent, it is not a rod knock or wrist pin. I still think it's an exhaust leak because you state it comes on when warmed up. Metals often expand enough to open up gaps between the gaskets when the engine is at operating temp.
I can almost bet your oil analysis will come back squeaky clean.
I have the exact same noise as the OP. I'm hesitant to suspect an exhaust leak considering the noise stops as soon as the engine comes off idle. Wouldn't the noise be louder or at least somewhat more noticeable if you press the accelerator while holding the brake? I too just finished towing about 9K lbs worth of tractor this weekend and it runs like a top.
Old Aug 26, 2019 | 04:03 PM
JackalAR's Avatar
JackalAR
Every exhaust leak I have heard has had a distinct tick, like a loose spark plug bleeding compression. They can come and go though too, but I'd place good money it it not being an exhaust leak. Will get under there ASAP, but won't be this evening.
Old Aug 26, 2019 | 04:18 PM
MJAB's Avatar
MJAB
Please let us know if you find anything. I was actually underneath mine yesterday trying to locate the source to no avail. Mines been doing it intermittently for about 10K miles and has not gotten worse. The oil analysis put my mind at ease a bit but the noise still concerns me somewhat. I'm thinking it may have something to do with the cam phasers as the oil pressure changes when the idle bottoms out. My wife's 4runner (OHCs) makes a similar noise under similar circumstances and the internet lore on those engines says it's completely normal valvetrain noise.
Old Aug 26, 2019 | 04:48 PM
JackalAR's Avatar
JackalAR
I DEFINITELY will. I hadn't owned anything with cam phasers before, so my ears aren't attuned to it.
Old Aug 26, 2019 | 06:33 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Take the belt off and I'm and eliminate 90% of the sources.
Denny
Old Aug 26, 2019 | 06:43 PM
JackalAR's Avatar
JackalAR
...then there is this:
Old Aug 26, 2019 | 07:15 PM
MJAB's Avatar
MJAB
Yep..mine sounds like that. Just not as loud or as pronounced as that video. Same frequency and tone.
Old Aug 27, 2019 | 10:21 AM
DSLTRK60's Avatar
DSLTRK60
That sounds like a loose coil conductor, almost like an arc.
Old Aug 27, 2019 | 07:58 PM
JackalAR's Avatar
JackalAR
Maybe you're having the same problem I noticed with my vids. Try watching it on your phone.
Old Aug 28, 2019 | 05:31 AM
Ron94150's Avatar
Ron94150
Would you please stop ignoring Rvpuller!
He is more than likely right, it's just belt slap, hence the reason you only have the problem at idle. While it's not a common thing, it's not abnormal for the belt tensioners to go bad on these things fairly early. Spend 2 minutes taking the belt off, start the truck, see that your problem is gone, spend 5 minutes putting the belt back on, then you can confidently report the problem to your dealer for a 1 hour service session while you mustang shop.
Old Aug 28, 2019 | 10:04 AM
JackalAR's Avatar
JackalAR
I may try it this weekend since it's a legit troubleshooting step and eliminates those accessories as a source. The Mustang has been secured at a dealer 5 hours away.
Old Sep 28, 2019 | 04:49 PM
  #28
Smiggles1970's Avatar
Smiggles1970
Trailering
Add me to the list of low RPM knocking. I watched those videos a few weeks ago and could not hear what the OP was describing. Now that I noticed my truck is doing it, I distinctly hear it in those videos. Raising the RPM would probably solve the issue. I wonder if there is a Forscan setting for increasing idle speed.
Old Sep 28, 2019 | 06:06 PM
  #29
leadmic's Avatar
leadmic
The injectors are a know source of a loud ticking noise on the 6.2s. I'm not sure why the injectors are so loud, but mine has the ticking noise and has had for 98,000 miles.
Old Sep 29, 2019 | 10:30 AM
  #30
JackalAR's Avatar
JackalAR
It's not injector tick.
I have been too lazy (other projects) to pull my belt and have a listen.
