Rough running
Old Aug 20, 2019 | 10:01 AM
PatrickBurke's Avatar
PatrickBurke
Rough running
Since i put new plugs into my 91 F250 it has been running really rough and stalls when i come to a stop. I put it on the OBD 1 reader and got codes 18 & 34. I have looked all over and even asked google what these codes meant but havent been able to find out. Also if the plugs are not firing right could that be the cause of the codes?
Old Aug 20, 2019 | 10:16 AM
Magnum3672's Avatar
Magnum3672
Did you gap the plugs correctly?
Are all of the wires seated properly?
Are the connections clean of rust and corrosion?
Which engine is it so we can help look for the codes.
Quick Edit.
Found this site with all of the OBD1 Ford 2 digit codes. https://therangerstation.com/tech_li...gitcodes.shtml
Old Aug 20, 2019 | 10:33 PM
PatrickBurke
It is the 5.8ltr. The 351 W
Old Aug 21, 2019 | 07:06 AM
rla2005's Avatar
rla2005
It would not be the first time to get a bad plug... As asked before did you verify the plugs were gapped properly? Did you replace the plug wires and/or the cap and rotor as well?
When were the codes displayed? During the Key On Engine Off (KOEO) tests, Stored Code display from Continuous Memory (CM) or when running the Key On Engine Running (KOER) tests.
The code definitions can changed based on when they were displayed. Code 18 is related to the ignition (SPOUT or IDM signal). Code 34 indicates a problem with the EGR valve position. Need to know when the codes were displayed to guide on where to go next.
Poorboy04
Aug 19, 2012 05:19 AM
wil-kee
1983 - 2012 Ranger & B-Series
Feb 26, 2011 09:13 AM
true blue
May 7, 2010 10:50 AM
Dre82s
Apr 23, 2008 09:29 AM
East mountain 99
Jul 8, 2005 07:00 PM
