I have a 01 F250 stroker that started running rough, I can not pull any codes out of it but the check engine light stays on. I am unable to reset the light. Any ideas?
look for TSB'S for rough running MIL on no codes.
but i will tell you this. the reader @ autozone is just that...a reader.. not a scanner and may not recognise diesel codes if they are not a normal gas job P code. go to a tech and have him look @ it for you. i only charge 1 hr to scan and do some simple diagnosis w/ a flow chart. otherwise you will be throwing parts and possible unessessary cash @ you mule.
