Throttle delay
Old Aug 19, 2019 | 09:52 AM
Jeffpace30's Avatar
Jeffpace30
Throttle delay
After I replaced the Hpop I had a serious delay in the throttle. And when I pull up to s stop sign, the Icp pressure drops below 400 and the engine dies. Disconnected the ICP. No more throttle delay. Bought a new ICP. Put it in. Same issues. Someone told me it could be the Idle Validation Switch. But if that was the case. Why would the problem go away when I disconnected the ICP? The only time the CEL came on was when I disconnected the ICP. Is this a PCM problem? Or do I have a Faulty “new” ICP? The fuel pump and cam sensors are new too.
Last edited by Jeffpace30; Aug 19, 2019 at 09:54 AM. Reason: Need to add something.
Old Aug 20, 2019 | 10:06 AM
knottyrope's Avatar
knottyrope
What year truck?
What style HPOP?
Did you take it our for a good run after to purge the air out?
Can you monitor IPR% duty at idle, 1k RPM and 2k RPM cold then check again hot.
make sure engine oil is not low
Old Aug 20, 2019 | 06:07 PM
Jeffpace30's Avatar
Jeffpace30
After watching the pressures, I put the old IPR in the new HPOP. Fixed the problem. The new IPR that came with the HPOP was defective. Getting another new IPR.
Old Aug 21, 2019 | 08:00 AM
knottyrope's Avatar
knottyrope
That isn't fun to go through. What HPOP did you get?
aquaman
2004 - 2008 F150
Dec 14, 2015 11:33 AM
Dales F-350
Jan 2, 2010 09:34 AM
davidsenna
Jan 12, 2007 10:22 AM
whalerron
Modular V8 (4.6L, 5.4L)
Jul 18, 2006 10:01 AM
greenroses
2004 - 2008 F150
Apr 23, 2004 06:03 AM
