Ton or half ton
Old Aug 17, 2019 | 02:30 PM
ynot321AB1's Avatar
ynot321AB1
Ton or half ton
VIN 97 HC180741, VIN decode says invalid VIN but highway patrol that did verification said everything ok. Have been told that since it has air vent at bottom of windshield makes it a one ton. Bonded title does not include ton rating.
Old Aug 17, 2019 | 02:42 PM
Steve Harlow's Avatar
Steve Harlow
If it's a '48-'52, the cabs were identical from the F1 to F8, barring the COE's.
Old Aug 17, 2019 | 03:08 PM
FortyNiner's Avatar
FortyNiner
As Steve mentioned, the non-COE cabs were all the same for that vintage. The cowl vent isn't a differentiator. Pics?
Old Aug 17, 2019 | 03:56 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by ynot321AB1
VIN: 97HC180741
Online VIN decoders usually do not recognize older 10 digit VIN's and the 11 digit VIN's used 1953 thru 1980.
Beginning in 1981, all auto makers VIN's used on vehicles sold in the US/Canada were standardized and contain 17 digits.
Old Aug 17, 2019 | 04:02 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
The HC says it’s a 226 flat head six cylinder half ton. Stu
Old Aug 17, 2019 | 04:12 PM
ynot321AB1's Avatar
ynot321AB1
Thanks to all for the info
I was confused as I had checked with LMC regard parts for the cowl vent and was told only one ton pickups had this.
Old Aug 17, 2019 | 04:15 PM
NumberDummy
LMC usually doesn't have a clue, their catalogs are rife with errors and omissions, their applications are 'cloud coo coo land' they have no Ford parts catalogs to verify anything.
When you call, a minimum wager answers, these people just take orders and that's it.
Old Aug 18, 2019 | 09:46 PM
mtflat's Avatar
mtflat
I wondered where you got the info about the cowl vent - that's a good one!
Old Aug 18, 2019 | 10:00 PM
Matt Js 54's Avatar
Matt Js 54
Yeah, I had a similar experience with LMC recently, the fuel pump for the 54 223 is listed incorrectly. They did look it up and I got a response from two different people telling me that they're going to update the next catalog, so at least I guess they listen. That said, you're not getting an expert on the phone.
I'm not claiming to be the greatest expert on this, but I think if the truck is a 1-ton then you'd have the heavier rear end, if I'm not mistaken it would be a two piece drive shaft, but don't trust me on that. Big springs, too. You'd have the heavier wheels, not 5-bolt. Some one tons did come with single rear wheels instead of dually rear wheels, but they are beefy. I think you'd have a 4-speed floor shift too, again if I'm not way off. The only way they could rate the truck for such a heavy load is through gears, so they'd be pretty low, and the reason for the 4-speed. Imagine a dump truck with a 105-ish HP motor. And it worked fine!
Old Aug 18, 2019 | 10:33 PM
abe's Avatar
abe
You could get a F350 tonner with a three speed on the column. I just saw a 53 F350 with 3 on the tree on eBay tonight.
Old Aug 19, 2019 | 01:38 PM
Matt Js 54's Avatar
Matt Js 54
Geez, what kind of gear must that thing have, 900:1? I'm kidding of course, but I can't imagine what the driving experience with that is. I recall they did have a heavy duty 3-speed, that must be it.
It goes to show that back in the not too distant past, you could customize pretty much any vehicle in lots of different ways. Of course people used to order a vehicle and wait for it to be built, but you got what you wanted!
Old Aug 19, 2019 | 09:31 PM
abe's Avatar
abe
Yes, a HD 3 speed.
robbv
1947 and Older Ford Trucks
Sep 5, 2017 05:53 PM
F&M
Sep 20, 2014 11:57 AM
seizure66
16
Sep 17, 2010 04:49 PM
mile_high
Nov 6, 2003 05:17 PM
mrmack070
Feb 14, 2002 10:14 AM
