Over drive button not getting power
Old Aug 17, 2019 | 01:11 PM
Wetcatcarl's Avatar
Wetcatcarl
Hey y'all. First post and hopefully someone can help.OD button isn't working and I already replaced the lever. Truck shifts fine but can't turn OD off and I haul a trailer a bit. It seems it's not getting power when I check volts on the red/yellow with key on. The wires look good on the plug end that goes to the PCM but I can't see all of them. How should I narrow this down and find the solution? Vechile is a 93 150
Old Aug 17, 2019 | 02:01 PM
Franklin2's Avatar
Franklin2
Pull the codes. See if you have a code 97 or a code 629.
Old Aug 17, 2019 | 02:14 PM
Wetcatcarl's Avatar
Wetcatcarl
I have a code 628 saying I have converter slippage.
Old Aug 17, 2019 | 08:22 PM
Franklin2's Avatar
Franklin2
Does the OD light ever come on? If the transmission has a serious problem, it may go into a limp mode where most of the features don't work and it runs the hydraulic pressure high to keep it going. Does it shift harsh?
Old Aug 17, 2019 | 08:36 PM
Wetcatcarl's Avatar
Wetcatcarl
No it doesn't shift hard. I got it sorted out. The new shifter I installed had a bad wire inside of it. I pulled off the housing around the shifter itself and found it. I spliced in new wire and wrapped it in heat shrink and electrical tape. Crazy cause I know the shifter I installed was fine before. It came from my parts truck and remember it working. O well. Fixed
Old Aug 17, 2019 | 08:39 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Old Aug 17, 2019 | 08:44 PM
Franklin2's Avatar
Franklin2
Good...........
Old Aug 17, 2019 | 08:51 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
[QUOTE=Wetcatcarl;18806487]No it doesn't shift hard. I got it sorted out. The new shifter I installed had a bad wire inside of it. I pulled off the housing around the shifter itself and found it. I spliced in new wire and wrapped it in heat shrink and electrical tape. Crazy cause I know the shifter I installed was fine before. It came from my parts truck and remember it working. O well. Fixed[
doucetrr
Dec 15, 2018 02:23 AM
aspenly
Mar 30, 2017 10:51 AM
71dusterjon
Jun 21, 2009 09:36 PM
donks
Mar 6, 2005 07:08 PM
baja_stx
2004 - 2008 F150
17
Apr 27, 2004 11:17 AM
