Obsolete auxiliary a/c part.
Old Aug 17, 2019 | 10:00 AM
jaxomlong's Avatar
jaxomlong
Hi- Looking for F75Z-19A522-AA, which is the controller on top of the auxiliary a/c behind the right wheel well. It's a circuit board above the blower that is in with the jack.
Several Ford parts sites are showing it obsolete. Neither my blend door nor my floor ceiling doors are working and this is the first common part up from the acctuators. The potentiometers test good at the ceiling drivers position.
Any help would be appreciated.
David
Old Aug 17, 2019 | 10:35 AM
Stewart_H's Avatar
Stewart_H
Try Circuit Board Medics and see if they can help. https://circuitboardmedics.com/
Stewart
Old Aug 17, 2019 | 11:09 AM
jaxomlong's Avatar
jaxomlong
Thanks-
Worth a try but I'd like to try a wreck first (I've looked at the site and I don't see a specific service). It's the weekend.
David
Old Aug 17, 2019 | 11:53 AM
Theboneskes's Avatar
Theboneskes
Can you post a pic of the part your looking for? Some Expedition parts work on Excursions for AC.
Old Aug 17, 2019 | 12:39 PM
jaxomlong's Avatar
jaxomlong
Here's a pic
Both the door actuators flow up to this module and both are acting the same way- the motors are pretty centered and just fidgeting a little back and forth. You can see actuators high in the pic. I took one side of the cover off (thank you Canadian guy on YouTube) and watched it.
Last edited by jaxomlong; Aug 17, 2019 at 12:45 PM. Reason: Issues with phone and computer
Old Aug 17, 2019 | 01:59 PM
01__Excursion's Avatar
01__Excursion
Are they fidgety when only installed to the air box?
I found this and posted a few pics , as something to consider when trouble shooting airflow issues on the rear system.
https://www.ford-trucks.com/forums/1...-consider.html
Old Aug 17, 2019 | 02:38 PM
jaxomlong's Avatar
jaxomlong
No, I tested them off the assembly.
I acctually opened them up with the electrical connectors on and watched the insides while my daughter moved the pots up front. The motors would turn two or three times one way and then two or three times the other while staying pretty neutral. Note this is not the part the inserts into the door- given the gearing of the motor to the actuator the part that moves the door hardly moved at all.
Part of my suspicion is that the actuators were in neutral- both of them. The pots a bout 50-5000 ohms, which is in spec. But the actuators were neutral and didn't go off it enough to matter.
David
Old Aug 17, 2019 | 02:42 PM
jaxomlong's Avatar
jaxomlong
Oh- and the heater blend door did feel like it wasn't moving enough. I'll pull off the duct and reach inside to check when I get a chance.
Taking it to Pennsylvania tomorrow to look at a train show with my ten year old.
David
Old Aug 17, 2019 | 08:10 PM
Kapusta's Avatar
Kapusta
Would it be worthwhile to try get one from a wrecking yard? It supposed to be the same from a 97 to 05 Expedition. There were quite a few Expeditions in the yard by me.
Old Aug 18, 2019 | 09:13 PM
jaxomlong's Avatar
jaxomlong
I have an e-mail in to a yard that had several actuators up on e-bay.
the website also showed several Excursions wrecked. We'll see.
Old Aug 21, 2019 | 08:34 AM
jaxomlong's Avatar
jaxomlong
The reference I'm looking at say 97 Expedition (& 98 Navigator) through 2002, and then Excursion through 2005.
https://www.cheaperfordparts.com/oem...y-f75z19a522aa
1low50
Jul 21, 2018 06:19 AM
Gregsilverlariat
2009 - 2014 F150
Jun 7, 2017 06:56 AM
sinnedam
2004 - 2008 F150
Jan 21, 2013 09:30 PM
CueMan's 78 F-150
Apr 27, 2011 09:02 PM
