Defrost mix not working
Old Jan 20, 2013 | 03:44 PM
sinnedam's Avatar
sinnedam
So my defrost works and my floor works but when i put my heater on defrost/floor mix it only comes out in the floor not the windshield. Any ideas?
Old Jan 20, 2013 | 04:16 PM
MCDavis's Avatar
MCDavis
Likely the blend door. Run a search for it.
Old Jan 20, 2013 | 05:55 PM
sinnedam's Avatar
sinnedam
Hhmm i may not be searching the right thing but everything i see os related to temp controls. Thats not my issue though. Help please.
Old Jan 21, 2013 | 05:58 AM
60DRB's Avatar
60DRB
I agree, the blend door is likely at fault.
If you have the "auto" climate control there is a self test that can give you some problem codes.
https://www.ford-trucks.com/forums/986532-2008-eatc-self-test.html
Old Jan 21, 2013 | 06:06 AM
sinnedam's Avatar
sinnedam
I dont. Mine has the manual *****. After checking again this morning, it does blow out somewhat, but its very weak. I know it will be weaker on mix mode than if it were on full defrost, but I have to set my fan speed to max before you can even feel it blowing through the defrost vents up top, whereas the floor portion of the mix is fine on any speed. I should have mentioned I have the manual controls. Also it is an 05 FX4 if that matters.
Thanks guys.
Old Jan 21, 2013 | 02:03 PM
tooldad's Avatar
tooldad
Plus 2 on blend door. It is electronically actuated and is well known to crap out. I have had at least three replaced on my '06. Never doen it myself, but believe it not to be difficult to replace yourself. does not take the Ford shop techs long at all to complete. all in knowing the secrets I guess.
Old Jan 21, 2013 | 02:06 PM
tooldad's Avatar
tooldad
Would not hold my breath, but was told once (by dealer) to try disconnecting the battery to reset the system prior to replacement. This potentially could allow the actuator to reset itself. Still think you will need a replacement, but no harm in giving this a try.
Old Jan 21, 2013 | 04:57 PM
Papa Tiger's Avatar
Papa Tiger
U have 2 doors, one for degree of heat and one for position of heat. Check your 2nd option. The third door is for Air Conditioning.
Old Jan 21, 2013 | 05:03 PM
sinnedam's Avatar
sinnedam
Any idea which is which?
Old Jan 21, 2013 | 09:30 PM
Papa Tiger's Avatar
Papa Tiger
Let's try this.....
Click this bar to view the full image.
They are hard to see since the power pedal motor/plug is in the way. not the easiest to get in there with your fingers and a wrench let alone a camera! The bottom motor controls air to panel/defrost/and floors.
DetailerDave
Jan 5, 2016 01:09 PM
cact34r
Feb 17, 2010 08:41 AM
cjstang
1997 - 2003 F150
Feb 3, 2005 10:40 AM
bigcountry1009
Jul 8, 2004 08:39 PM
