General Automotive Discussion
Tail lights?
Old Aug 16, 2019 | 06:03 PM
Truckdream's Avatar
Truckdream
Tail lights?
Sooo don’t boot me for saying this lol. My main ride right now is a Chevy S10. My project truck is the 94 Ford F-150. Anyway I had to change the fuel pump today in the S10 as it was broken. Got it swapped out.
In the process I removed the truck bed. I found some other minor issues one being small rust spots in the bed. I removed the cheap plastic bed liner and went crap. So I’m gonna fix the rust issues and put a paint on or spray in bed liner in it. Before putting it back on the truck.
Anyway I need to drive this truck but right now it has no tail lights because the bed is off. Will those magnetic or clip on trailer lights if I hook the 4 flat back up and plug them in without having the regular lights plugged in? I don’t want to spend money on the lights if they are not going to work.
Old Aug 16, 2019 | 11:27 PM
ford2go's Avatar
ford2go
Short answer is that they should be OK -- if they provide all of the functions (turn/ brake/tail) when they're just hooked up to a trailer. There's no real magic in the truck tail lights. It should even blink at the normal rate ( adding trailer lights would make the turn signals blink faster).
Only thing is if they happen to be LED lights you will need an LED flasher.
hj
Old Aug 17, 2019 | 07:55 PM
Truckdream's Avatar
Truckdream
hj
Cool thanks. I’m going to try it.
Old Aug 18, 2019 | 05:16 AM
tjc transport's Avatar
tjc transport
i ain't rite
i used the magnet tow lights on the rear bumper for two weeks when i had the bed off the 04 for frame rust remediation.
they worked fine plugged into the trailer plug.
k4owb
Aug 25, 2023 07:58 PM
RV_Tech
All Things Towing
Nov 5, 2015 07:47 PM
-Doc-
Sep 9, 2007 04:42 AM
53choptop
Mar 20, 2002 11:31 AM
