Transmission shudder
HI started talking about this in an existing post, but thought I’d continue here in my own thread. Long story short, my tranny shudder (2010 4.6 scab) is back after about 40k miles (currently 68,000 miles) and 7 years. Does anyone know a way the do a complete fluid change at home with a 6R80? I haven't found anyplace that shows if the torque converter can be drained. The posts I have seen, just say do a pan drop and filter change and let it go at that, or if you want to go further, you’ll need to try an exchange at the lines at the transmission cooler after the pan fluid exchange. Also, it there any way to see if the truck has the most current program installed for the transmission? I also plan on looking at the condition of the current fluid as soon as we take our grandkids back home this weekend.
There is a software upgrade to the transmission.. You should check with FORD to see if you have that.. If it has not been upgraded in the past 90 days, then you probably do not have it.
There is no way to drain the converter. I removed the pan and cleaned / changed 5 quarts of fluid. I welded a 3/8 NF nut to the pan and installed a short bolt as a drain plug. I plan to change 5 quarts of trans fluid every year. Never will be 100%, but should keep the oil in very good condition..... about 13 quarts system total.
Thanks for the tip. I did check the fluid and it looks dirty enough to change, not bright red, but rather brown. It was also low enough to not register on the dipstick, even though there are no leaks and the coolant looks good showing no intermixing of fluids. The stupid little dipstick cover was rusty enough that I wasn’t sure it was could be removed. Turns out it’s beefy enough to handle it, at least for now. I bought some fluid and plan on doing a complete change with a new filter. I plan on cycling new fluid into it as I let dirty fluid out at the cooler line. I just need to get my son-in-law to help out. I helped him do his Mercedes, so I’m sure he won’t mind helping me. Not sure if your Lincoln has the 6R80 transmission, but I may pick up some shudder fix fo the future. There seems to be TSB’s indicating a possible torque converter problem, but I can’t get the “stealer” to look into it without a service charge. Call me skeptical, but I think they just want to charge me, and not help me.
The color of LV fluid is not an indicator of anything, it's the nature of the beast. If mine were shuddering then I'd definitely have it changed. I had mine done this spring just because I had reached my 90,000 mile mark and that was my line in the sand for tranny maintenance. I was expecting a flush and instead the dealer did a pan drop and filter change. Feels like new.
My visit to the transmission shop was somewhat disappointing, because the said they didn’t detect a problem on the test drive. I opted to have the transmission back flushed anyways, but disappointed that they wouldn’t use the fluid I had already purchased. I haven’t driven it enough at this point to pronounce it fixed, but it does seem okay. I will post updates later if it comes back.
I’m not a transmission expert, but they take the pan off and use a machine to flush it, or back flush as I understood them. In this way, the crap in the torque convertor gets flushed out. They told me that running the truck, opening the line at the cooler and simultaneously replacing lost fluid at the dipstick would not sufficiently flush it. But it’s possible I’m misunderstanding.
